460 Throttle response question, sputtering
Old Mar 1, 2007 | 09:16 PM
86rustbucket's Avatar
86rustbucket
Need some help, if I stab the gas quickly when the engine is at idle, it doesn't pick up right away and typically sputters and almost stalls. I'm not sure if it is an ignition or fuel issue.
Specs are as follows:
1987, 460 - stock bore and stroke, new bearings and piston rings, stock heads with mild exhaust porting (removed smog bumps, smoothed valve guides, etc) intake ports cleaned up
Holley 770CFM truck avenger carb
Dura Spark ignition, nothing special, new distributor and module
Weiand Stealth intake
Heddman full length headers into high flow dual inlet / outlet cat with Dynomax muffler
Cam specs:
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 218 int./228 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 286
Advertised Duration: 276 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.503 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.503 in.
Lobe Separation (degrees): 114
No EGR, No A.I.R. pumps
Manual tranny (T-18)
Double roller timing chain installed straight up (no 8 degree retard)
Ignition timing set at 8* BTDC
I'm kind of worried that the carb might be a little too much, but it was what Holley recommended for the engine.
The only other thing I was planning to change was swapping out the stock can type coil to a TFI coil that I had from the EFI 351 that was in the truck to try and get a little more spark energy.
Any thoughts / ideas? If I hold the engine RPM a little off idle (above 1200 or so RPM) there is no sputtering if I rev the engine.
Thanks,
Dave
Old Mar 27, 2007 | 01:28 PM
86rustbucket
Quick update just in case anyone else has a similar problem.
Vacuum advance was plugged into a full vacuum source, changed it to the vacuum port meant for the distributor on the holley carb. Still didn't fix the problem completely.
Adjusted vacuum advance with allen wrench in vacuum port on distributor until the sputtering went away.
I'm assuming that I had too little vacuum advance.
Old Apr 3, 2007 | 08:03 PM
shawner's Avatar
shawner
I have the same problum. I had to set my timing all the way up to 20* untill sputtering went away. Seems too high to me. What size allen did you use and what way did you turn it? I need more advance under a load but not 20* initial timing
Old Apr 4, 2007 | 01:42 AM
darrin1999's Avatar
darrin1999
i think its starting to flood out since it only does it at low rpms... you could change the carb to a 600-650 or change out the metering block
2.5itim
18
Sep 6, 2016 01:53 PM
JRS2
28
Jun 25, 2016 07:02 AM
NIdude
Apr 14, 2015 10:25 PM
SCRebel
1997 - 2003 F150
Dec 28, 2013 09:56 PM
CowboyFromHell
Apr 22, 2009 11:08 PM
