Greasable Polyurethane Leaf Spring Bushings
Old Mar 1, 2007 | 08:44 AM
moonley's Avatar
moonley
Greasable polyurethane leaf spring bushings...where can I get them?
I just ordered all new leaf springs for my 1970 F250 4x4, before I install them I want to upgrade to polyurethane bushings with greasable bolts all the way around...problem is I can only find applications for every year, make, and model other than mine, and my google searches bring up nothing. Any help pointing me in the right direction is greatly appreciated!!
Old Mar 2, 2007 | 11:32 AM
airharley's Avatar
airharley
They may not be specifically for your F250 but bolts are bolts as long as they fit the same application.
http://diy4x.com/suspension.htm
It may take a little research to find a company that sells your size bolts. But they are out there. I came across link with a guy who made his own on a drill press even.
Old Mar 3, 2007 | 09:52 PM
moonley's Avatar
moonley
Thanks for the link.
I was also able to find bolts here:
http://www.tellico4x4.com/index.php/...8142e717560dd8
and front bushings here:
http://www.jackit.com/bushings/ford_bushings.htm
But I still can't find rear bushings. I was also hoping that I could get a greasable bushing kit so that it would have the necessary grooves cut into the bushings to aide in lubrication. If anyone has any more suggestions or knows other applications that will fit I would appreciate your help. Thanks again,
Nick
Old Mar 4, 2007 | 08:14 PM
Dave Severson's Avatar
Dave Severson
With poly rod ends, I drill a 3/32" hole thru the rod end and the bushing, then counterdrill the rod end and tap for a regular screw in grease fitting. Spring steel would be a lot harder to drill, but I believe you could do the same thing. I don't bother with the grooves, the poly bushings work so much better then rubber bushings with a steel sleeve I don't think they need the grooves..... Not sure it would work on your application, just thought I would let you know.
Old Mar 5, 2007 | 10:02 PM
moonley's Avatar
moonley
Ok, so I can find a source for greasable bolts and a few for front polyurethane bushings, but nobody seems to make the bushings for the rear springs on my truck. Most of them do list for 67-72 F100 though. Wouldn't these be the same? I'm about 7,000 miles away from my truck right now or I'd check it out myself. Thanks.
Old Mar 6, 2007 | 03:06 AM
airharley's Avatar
airharley
Checking an auto parts website the F100 and F250 have different MOOG part #'s for the stock bushings. On the other hand Norris-McQuay list the same ones. Your best bet is to wait until you get back from eating sand and measure them to be sure.
302flareside1992
Aug 29, 2016 05:14 PM
waylen89
Aug 8, 2016 03:45 PM
aville
Apr 17, 2016 12:01 PM
tabascom16
Mar 2, 2015 07:01 AM
FordFETruck
Jun 25, 2013 04:12 PM
