All turn signals not working
Each one of my turn signals is solid when I use it. I checked the fuse, and all is well. I haven't dug into my repair manual yet to find out how to test the switch, but I plan to.
Has anyone ever experienced this before? What's weird is last month the signals started to go on the fritz - they would blink fine, then pause, then go solid. A few weeks later they worked fine. Now they just light solid.
Glad to hear you got it fixed. Question for you though, do your turn signals blink any faster with the new flasher module?
Mine blink a bit too slow for my tastes. Annoying when trying to signal on the freeway, and it takes a whole second for the light to come on. I thought I might just get a new module and see if it helps.
I had the same problem get a heavy-duty flasher or try one of the electronic ones I got one of them and it really works great cost a buck or two more but they are supposed to last longer. The heavy duty and electronic ones work better because they are built for the extra pull you get from trailer lights. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Rick
