I have a 92 areostar that has 200,000 miles on it, however at 198,000 miles we put a rebuilt tranny in and a new convertor.When we first had the tranny in it worked GREAT for about 1200 miles and then it would not shift right what would happen is when we would first go on the road it would stay in low gear and after about a quarter mile it would kick into drive and run fine for the rest of the day. then go out the next day and it would do the same as the day before. I changed the filter and put trans-x into it and did this even after 20 miles of use. I NEED HELP.
Welcome Duke, nice to have you on board.
Here are the links to the forums here: https://www.ford-trucks.com/forums/index.php
Drop into to the Aerostar forums for dicussions and a ton of info on your Aerostar.
Be sure to join your local NC Chapter to make some new Ford truck friends.
