turbo???
Old Feb 28, 2007 | 10:00 PM
p521us's Avatar
p521us
turbo???
ok guys, im tired of searching around.....
is it possable to turbo charge the 300?
would i have to 'remote turbo' it? there doesnt look like theres enough room, but what do i know u guys are the expterts.
*random question* would drilling holes in my exause help or hinder the proformance/sound?
Old Mar 1, 2007 | 07:37 AM
Motorhead351's Avatar
Motorhead351
Yes, you can add a turbo to any engine.
Go to www.turbomustangs.com look at the knowledge base at the top, read everything (a few times) and you'll be an expert. Dont let the name fool you, its a site were all makes and models meet, trucks, cars, v8's, inliners. Check out the build ups and apply what others are doing to their engines, to your engine, its that simple. If you have a carb engine, its a no brainer, if you have the stock efi, then your gonna wanna find someone that can reprogram your stock computer, they are out there, you just have to dig. Another option is to use a standalone efi controller, read up on megasquirt, although, the more expensive well known companies could offer you something.
You can also go to www.fordsix.com look in the turbo,supercharger, nitrous section, see what the guys are doing with the small six.
Dont drill holes in your exhaust.
There is plenty of room for a turbo(s) in your engine bay. No need to remote mount it, although, if you dont do alotta offroading, where debri might damage the turbo and plumbing, that might be an option for you. I know many like to debate the whole remote turbo concept but the fact of the matter is, if thought out, it works and works well.
(you will probably have to copy and paste or type the links I provided into your browser, as this site likes to redirect links to the main page of this site)
Old Mar 2, 2007 | 02:32 AM
F-150battlemaster's Avatar
F-150battlemaster
I've done alot of armchair mechanics with this with the guys I work with.
The block and everything associated with it is built pretty stout. If you have an EFI motor then fuel pressure isn't going to be a problem even with the little 12 pound per hour injectors that come stock on the vehicle. If you wanted a cheap upgrade then even stock 15 pound an hour injectors off a 5.0 will do the trick. Though you would have to install an adjustable fuel regulator to reduce pressure to 35 psi or so. Thats close to factory specs for the 90 I run. An intercooler is going to be a must due to the location of the manifolds. The intake and exhaust being located on the same side of the head. You can alleviate the heat issue that arises from this by wrapping your exhaust. But refer to head cooling issues. My exhaust is wrapped from the manifolds to the cat with no adverse effects. But I don't have a turbo on my vehicle so I couldn't say what would happen with that.I guess there is this issue with coolant flow in the head not being as efficient as it could be. So you would have to watch out for that.
I have put alot of thought into doing a twin turbo install on my 4.9. Using a healthy dose of SWAG (Scientific Wild A.. Guess) I figure I could easily handle 30ish pounds of boost without blowing the motor . But I am looking for around 10-15 pounds of boost so I should be safe.
Anyways. Yes I have put some thought to it. Yes it can be done. Yes its going to be expensive as hell. And yes there is more to this but I don't feel like typing everything out. But its doable. And if your all for having bragging rights for having a 300+HP 300c.i.d. straight six. Then by all means go for it.
Old Mar 2, 2007 | 07:42 AM
Motorhead351
4.9 = 14 lb/hr injectors
5.0 = 19 lb/hr injectors
Not all 302 engines used 19 lb/hr injectors though, some were the smaller lb/hr.
Your gonna wanna do more than just add larger injectors, you have to in some way be able to add more fuel per boost and your stock ecm/map sensor is not capable of reading positive pressure. You may get a one to one fuel pressure increase with an adjustable fuel pressure regulator but Id think an adjustable FMU or fuel management unit would be a good idea. There is a few ways to mechanically skin this cat but in any case, your just throwing fuel at it and hoping for the best.
Ideally you IMO should go with an aftermarket efi controller. If you go with an aftermarket efi controller, such as a megasquirt or one of the more expensive companies, you will get a map sensor that reads positive pressure aka boost and you can fine tune the fuel/timing maps accordingly, then when you add the larger injectors, you can control the pulse width and actual fuel maps vs just fuel psi. This method is a little more efficient, as you have an idea of what is actually happening and total control over it.
Shouldnt need an intercooler due to the header/intake placement, using low boost. A heat shield might be a better idea.
Wrapping your exhaust usually isnt a good idea, but those interested in boost usually dont care about the negative effects, just as long as they can get the turbo to spool efficiently.
Good luck getting a decent head gasket, thats one of the big issues with the inline six engine.
Have fun.
Old Mar 2, 2007 | 08:25 AM
Silver Streak's Avatar
Silver Streak
After how long? 30 Seconds? By simply typing "turbo" into the search function there are multiple threads specifically about this topic, including a couple that basically tell you exactly how to do it, within the first 2 or 3 pages of threads. Info about how strong the stock short block isn't and how to compensate for the added airflow are all in there.
On the headgasket, Flatlander Racing will custom build one out of copper in almost any thickness for under $200.
Old Mar 2, 2007 | 06:16 PM
broke77f100's Avatar
broke77f100
my LAST resort after i do get my engine built and whatnot and it doesnt make the 500HP im hoping it does...im goin TWIN TURBO!!!YEEEAAAH
Old Mar 2, 2007 | 06:33 PM
Motorhead351
Hey, Id love to see a turbo 500hp I-6 that pulls my truck through town too, just not likely. Can you imagine the torque output of a turbo charged engine pushing 500hp, even at the upper rpm it would be impressive.
Old Mar 2, 2007 | 06:38 PM
broke77f100
hybrid head? u mean like those crazy LS1 heads that people cut and weld together for the I6?...and i believe it is VERY likely...maybe even without the turbo...most of the parts will be coming from Clifford Performance..Ford Six Performance Parts..Crane Cams..MSD..Some other stuff(i cant remember everything cuz imma bit tired at the moment)
Old Mar 2, 2007 | 06:41 PM
Motorhead351
Best of luck man.
Old Mar 2, 2007 | 06:43 PM
broke77f100
Thanks. Most people have no support for the idea of a high output six....even if it doesnt make the 500HP i want it too...it was still worth the effort to say i did do it
Old Mar 2, 2007 | 06:48 PM
Motorhead351
Well man, thats not true. Im all for a high ouput six. However, as time went by, I read, searched, read some more, I realized, it would require alotta rpm to reach an appreciable HP level with the inline six. A high rpm engine and a heavy truck, just dont mix well.
Now if you wanna talk turbo and the inline six, Im sure you could make some impressive torque output, only way your gonna get some rpm out of it though to build hp, your gonna have to do something about the head and its not gonna be cheap.
I wish you the best though, If I in good concious thought 500hp was possible with the six and still be a street truck friendly engine, Id be cheering you on. Forced induction just might get you there. I definitely wouldnt wanna try it naturally aspirated.
Ive actually been chatting with a guy that has a 292 turbo, he estimates it around 450hp, reasonable boost, nothing insane. Thats a different bag of worms though.
Old Mar 7, 2007 | 01:22 PM
Pearlwhite94's Avatar
Pearlwhite94
i wanted to do this too but never really had the money or time to sit down and plan out what i would need. i heard of a guy who did turbo it but i lost contact with him, apparently he used the turbo from the chevy dualie and he was running 15psi. he had tons of problems though, he was running a megasquirt with it and had detonation (probably using cheap 87 octane gas and no intercooler). I believe he dynoed it at 230hp and like 450 torque, i wanted to do the same but im still in school and i cnat afford to pay for such a project. good luck though if u manage to pull it off i might model after you in the later years.
Old Mar 7, 2007 | 01:36 PM
Motorhead351
https://www.ford-trucks.com/forums/2...y-300-six.html
Old Mar 7, 2007 | 05:40 PM
p521us's Avatar
p521us
well i got my turbo!
im gonna buy it from a guy for $100 all i need is tubes
i herd the 300 would be able to take the pressure. this true?
its starting to roll!
Old Mar 10, 2007 | 01:36 PM
chtulu's Avatar
chtulu
You're going to be hard pressed to get 500hp out of a gas powered six. even the 5.9l cummins turbo diesel doesn't get 500hp....lb/ft, yes, but not hp...not without some major mods, i.e. turbo, exhaust, puter tune, etc.... and the cummins starts off with twice the hp as a stock 4.9---300hp vs. 150hp.
You're going to be very lucky if you double the hp on your six to 300hp. 225 would be more feasible. That's a 50% increase in hp, which should just about equal a 50% increase in torque, putting the motor at 225hp and 530lb/ft, give or take 20 or so lb/ft of torque. That in itself would be a beast to be reckoned with, especially offroad.
As far as mounting a turbo, if you're working with an injected motor, the exhaust is on one side, and the intake is on the other. you could either route the piping up and over the front/top of the plenum, and into the intake, or you could go underneath the motor (I would wrap the part of the pipe that goes under the motor, btw). The only problem you would possibly have is actually mounting the turbo and the pipes. Nobody wants their turbo flopping around under the hood.
Also, if you're working with an automatic tranny, beware. If you're one of the unfortunate ones of us that got stuck with the E4OD, find another tranny. Having to get an E4OD rebuilt costs around $2200.00 which sucks major cahones. I've had to have mine rebuilt twice, on a stock motor with less than 150k on the odo....
if you've got a 5spd....ignore what I just said.
Just remember that if you're going to go turbo, find a good head in your local junkyard and have it machined and honed and whatnot, so it will flow better.
And if I'm not mistaken, the factory compression ratio is pretty low, like 7.5/1 or something like that, maybe 8.0/1...so detonation shouldn't be a problem, either...but I'd run premium octane through it to be safe (if you use a stock head...if you have it milled, expect the cr to jump to 8.5/1 or slightly higher, depending on how much they mill).
But, then again...I could be wrong. Wouldn't be the first time, won't be the last.
