Sponsored by: Auxito
Better Brakes
Old Feb 28, 2007 | 07:00 PM
1998F150XLT's Avatar
1998F150XLT
Better Brakes
ok guys, I have a 98 f-150 and the damn thing has killed the front right brake rotor 2 times and my other 98 f-150 killed the same one as well. BTW it just went again and im pissed, I just replaced it 5k miles ago. Are there any non stock calipers that I can get for this truck. Its a 5.4L 4x4. I would LOVEEEE a Big brake kit but there pretty expensive so thats probably out of the question, unless someone knows of a cheap one or one for sale cheap new or used. I have slotted rotors with some nice pads already to help some but stock sucks . Also, the abs light jsut turned on, I assume its a sensor or something but would that have anythign to do with the caliper freezing up?
Old Feb 28, 2007 | 07:21 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome to the forum!
Are you warping slotted rotors? I would check to make sure the caliber isn't sticking.
Old Feb 28, 2007 | 07:24 PM
1998F150XLT
Im not warping rotors the caliper gets stuck, the only reason for better pads and rotors was to help with braking as best as I can without goign big brake kit. Im jsut wondering if there is a better caliper that can clamp harder that bolts up to stock stuff. If not im lookign for another caliper other then a ford caliper because these thigns keep getting stuck. Unless... is there some way... damn... maybe my front line is kinked and not letting the caliper retract?
Old Feb 28, 2007 | 11:27 PM
73f350sc's Avatar
73f350sc
Look into Willwood...they have a variety of options for all makes and models of vehicles. Theyre pretty reasonably priced if you want better performance and they may be able to set you up with something that works a bit better than stock. Should be able to call em and find out...thats your best bet so you can talk w/ a rep and figure out what works the best.
-Chris
Old Feb 28, 2007 | 11:31 PM
1998F150XLT
ok sweet, ill give them a call tomorrow, thanks
Old Feb 28, 2007 | 11:53 PM
73f350sc's Avatar
73f350sc
Yeah,
My buddy was gonna run them on his ranger...but he went with a long travel suspension kit that cost him a bit more than he anticipated lol. I've heard good things about them...they have big brake kits but they also have performance calipers for other applications all the way to motorcycles.
-Chris
Old Mar 1, 2007 | 12:00 AM
1998F150XLT
Originally Posted by 73f350sc
Yeah,
-Chris
yooo i saw that one for the motorcycle thats flippin swettttt.
Old Mar 1, 2007 | 02:08 AM
1998F150XLT
hey guys how about some front brakes off a lightning, will they work and are they any better?
Old Mar 1, 2007 | 10:01 AM
KingRanchMan02's Avatar
KingRanchMan02
I have heard of the rubber brake lines going bad on vehicles before. Causes the fluid to flow out to the caliper but not back into the system resulting in a locked caliper. Try replacing these lines at the front calipers. Good luck!
Old Mar 1, 2007 | 03:34 PM
1998F150XLT
iv been thinking of stanless braded lines maybe ill go with them and see what happens.
Old Mar 1, 2007 | 06:03 PM
lariat97's Avatar
lariat97
Stainless steel brake company sells caliper upgrades that fit stock rotors.
Old Mar 1, 2007 | 06:29 PM
1998F150XLT
that would be sweet if they had an upgraded stock caliper. However am i jsut missing it all i come up with is a big brake kit thats almost 2 grand. I have the slotted rotors and kevlar pads, so all i need is an upgraded caliper that bolts up to stock stuff. Do they have that?
Old Mar 1, 2007 | 06:40 PM
lariat97's Avatar
lariat97
Yes they sell upgraded calipers for stock size rotors. I have a styling concepts catalog with them listed. I'd check with Stainless Steel Brake Corporation online. I'd like a set for my F150. I have slotted rotors & Hawk pads but the stock calipers could be better. These upgrades are oversized cailbers for stock wheels or they have big brake kits too.
Old Mar 1, 2007 | 06:42 PM
1998F150XLT
hmmm ok, well i dont see anything on their site, ill just send them an e-mail. I have 18" wheels too, to bad i cant afford that 14" kit thad b sweet.
Old Mar 1, 2007 | 06:48 PM
lariat97's Avatar
lariat97
I guess you could check with stylingconcepts.com. They show them in the latest catalog.
