"eletric braking"
Old Mar 1, 2007 | 11:08 AM
TXHillCountry's Avatar
TXHillCountry
Yes, when you order your Prodigy controller, tell them you want the Ford harness.
It looks like this: (flat pin for the Prodigy side, square six pin for the Ford side.
Then, when you get it, take the panel off that is right under your steering column. It's the big panel with 4 plastic quick-lock screws. That will expose the fuse box on the left and a cavity on the right. Look all the way to the right throught the little "window" in the sheet metal. You'll see a gray plug attached. That's the trailer harness. It's held in place with one of those "ribbed" push-hole connectors, so you can pop it loose and you should be able to pull the harness out a ways to connect it.
See in pic below
Old Mar 3, 2007 | 06:03 AM
doberman's Avatar
doberman
Do you have to do any additional wiring for the prodigy. I have 04 f350 4x4 and am picking up new 5th wheel in two weeks.
Old Mar 3, 2007 | 07:26 AM
bkvanbek's Avatar
bkvanbek
No, when you get your Prodigy just ask for the harness for o4 F350, and it just plugs in.
