1978 - 1996 Big Bronco
whining from the front end
Old Sep 12, 2002 | 10:26 AM
JBronco's Avatar
JBronco
We must be talking about two different sounds then. Mine is not a gear whine, I know that sound! His might be a gear whine. I will rephrase mine to be a "squeaky, brake-like sound."
Old Sep 12, 2002 | 11:30 AM
LePewPewsicle010's Avatar
LePewPewsicle010
how can it be a gear whine if the front axle does not turn in 2wd with my hubs unlocked. it coming from the wheels
Old Sep 12, 2002 | 02:36 PM
JBronco's Avatar
JBronco
dej, I think it is the word "whine" that is throwing people off. That word usually does refer to a gear whine or howl. From your post though, I thought you meant what I am talking about, more of a squeaky sound coming from the wheel area. I still think it is brakes, probably a dragging caliper or even brake dust. Try blowing out all the dust from behind the wheels with a high pressure water hose or something (don't breathe all that asbestos dust in).
Old Sep 12, 2002 | 02:45 PM
RAzaRazor's Avatar
RAzaRazor
Heh... Brake pads haven't had asbestos for a loooonnnggg time.
Old Sep 12, 2002 | 06:10 PM
JBronco's Avatar
JBronco
Maybe he has really old brakes! I still wouldn't breathe whatever it is that they are made of.
Old Sep 14, 2002 | 02:14 PM
LePewPewsicle010
it is a little hard to describe the sound. it is kind of like a whistle sound that goes back and forth from a medium to high pitch sound. it alternated from medium to higher pitch medium, higher pitch, and it starts at 10 mph and either i cant hear it any more at 25 mph from road noise, or it goes away. any ideas. and some times it is silent, except i can do anything while driving to make it silent, but i have noticed that when it is silent if i tap on the brakes, the sound returns. i have not been able to do replicate that again cause lately it has not been silent.
what is the caliper design on Broncos? i had some one suggest if is a sliding caliper, that it might be frozen and only one side of the pads might be pushing and the other might be just riding on the disk making the noise, which would explain why when i tab on the brakes it does not go away cause the caliper is not pulling the other pad against the rotor and only one pad is actually pressing on the rotor. but if this was the case i would think it would be pulling when i would brake but it really doesnt do it at least i dont think it does.
any idead
Old Sep 15, 2002 | 09:49 PM
etherdan's Avatar
etherdan
This might be it. I have a 96EB and had the same problem. There is a rubber dust shield on the back side of of the front disc. This shield has dried out and the noise is the friction between the two. It is very difficult to impossible to lubricate this area. The noise stopped when I pulled the disc and repacked the bearings putting a little extra grease inside that shield. It worked for a year and started again. I replaced the shields, never came back. This shield is not on most models. I was told these came on a 96 1/2. Hope this helps.
Old Sep 16, 2002 | 12:20 AM
CityBronco's Avatar
CityBronco
F150MUTT
2015 - 2020 F150
Aug 12, 2017 02:29 PM
heavyhauler797
Dec 19, 2016 01:27 PM
BigBlkEX
Jan 10, 2014 09:41 PM
Craig5_12
Feb 12, 2011 11:25 AM
cekingsley
May 25, 2007 08:16 PM
