I have a chance to buy a 400 with a C6 (I think that's what it is) for $100. I'm sure this is a good deal, but what can I expect for $100? They came out of a Bronco.
M-block crankshaft casting ID codes are located on either the first counterweight (opposite the first throw at the front of the engine), or on the side of the first throw. Casting ID codes are recessed into the unfinished (raw cast) surface. Sometimes the characters are faint, so you may have to thoroughly clean the area with a solvent to find the ID code.
The 351M cranks are marked 1K or 1KA.
The 400 cranks are marked 5M. 5MA, or 5MAB.
If you have to rebuild it, swapping a 400 crank and pistons into it is a very small additional cost over rebuilding it as a 351M.
The 351C has a shorter deck height in the block (9.2" vs 10.3"). It has smaller main bearings and journals. It has the same bore and stroke as a 351M, being 3.5" Stroke and 4" Bore.
The bell housing bolt pattern mates a small block bell housing/tranny to a 351C, but you need a big block bell housing/tranny to mate to a 351M/400 motor, with exception of some rare 400 FMX blocks.
You might check the vin on the bronco if it is available and that would at least tell you if it originally had a 400. It is unlikely someone replaced it with a 351m if it originally had a 400, although possible. What year is the Bronco?
