Removing the headlights
Old Feb 28, 2007 | 01:11 AM
patriot88's Avatar
patriot88
I have a 2000 Expedition and I am having trouble removing the headlights. I tried to pull out the headlight brackets and I couldn't do it. I tried to pull the two metal clips out of place and there is a large screw that prevents each clip from being moved. The screws are parallel to the ground and there isn't much room to work with. Anyone else encounter this problem?
Also what are the best clear corners to purchase? Any websites or stores that you recommend.
Thanks
Old Feb 28, 2007 | 10:04 AM
buzzard's Avatar
buzzard
There are two strap-like pull tabs on the backside of the light housings. Pull upward (very firmly/sharply) on these and the headlight assembly will fall out the front of the grille area.
Old Feb 28, 2007 | 11:47 AM
gavinhaslam's Avatar
gavinhaslam
I had exactly the same issue. I wasn't pulling the tabs up high enough.
Those 2 tabs is all there is to it. You'll be amazed how cheap the headlight assembly feels when it comes out.
Gav.
Old Mar 2, 2007 | 01:13 PM
Greenscobie86's Avatar
Greenscobie86
^Yeah, just pull those tabs up. It helped when I pushed the tabs toward the front of the truck when i was pulling up on them. Just be careful not to mess up the little alignment guides on the lights when you are putting them back in, that way your beam pattern does not change. Good luck!
1L243
Dec 7, 2019 12:20 PM
cdnalpina
Mar 1, 2010 08:49 AM
sowaxeman
Apr 28, 2008 06:31 AM
eastside
1997 - 2003 F150
Sep 12, 2007 08:34 PM
Naga Sadow
1983 - 2012 Ranger & B-Series
Nov 11, 2004 07:19 PM
