460 fuel problems
Old Feb 27, 2007 | 08:22 PM
560farmall's Avatar
560farmall
Cool 460 fuel problems
hello ford fans im new here and need sum help please i got a 89 f250 with 460 in it my problem is it will start and idle for 10-15 min then die just like it aint getn fuel put a new fuel pump on it what can do to solve this problem when try drive it it run for about ten min also any help be appreciated thanks
Old Feb 27, 2007 | 10:22 PM
lewislynn's Avatar
lewislynn
I had the same problem with my motorhome. I don't know about your F250 but it sounds like when you are in start mode the fuel pump is on, when you are in run mode it shuts off.
On mine there are several switches it has to go through to keep the fuel pump on in run mode. Mine has 2 vacuum switches, an oil pressure switch and a rollover switch...And of course the ignition switch
In my case a connector for one of the vacuum switches melted on the manifold and shorted out.
Maybe someone with attachment posting privileges has a schematic they can post.
Old Feb 28, 2007 | 06:36 PM
560farmall's Avatar
560farmall
thanks for rhe help lewislynn and if sumone does have schematics sure would like to see
Old Feb 28, 2007 | 06:56 PM
lewislynn's Avatar
lewislynn
There should be an oil pressure switch on the back of your engine (behind the intake manifold) near the oil pressure sending unit. Start your engine and check it for power, as I recall that was the last switch before the rollover/inertia , switch...BTW, check out one of those manuals at the auto parts store or maybe even the library.
r9wolves
Dec 2, 2014 10:04 AM
bsmick69
Jul 27, 2011 08:13 PM
SBANANA1
Mar 12, 2009 08:08 AM
351c
1978 - 1996 Big Bronco
Aug 22, 2007 01:19 AM
prommach
Jul 24, 2007 06:05 AM
