Is it only me?? When I back up after truck has been setting for a while it sounds like the brake are dragging. I do not use the emergency brake. Any ideas welcome
my '05 does the same thing even if it only sits for an hour...original brakes...ceramics may or may not help, but i don't plan on replacing them til they wear out...
It's normal for everything with rotors. It's actually a very good sign, showing that your rotors are not contaminated with oil. The surface rust also cleans the glaze off the pads if you'll bear down on the brakes while the rotors are still rusty (a quick stop or two). Next time you go to the truck after sitting out in wet weather, just observe the rust on the rotors.
