so i was out driving today, i left a place and rolled my window on the driver side down, but when i hopped on the freeway and tried to roll it back up agian nothing happend. no noises no nothing, i pulled the panel off when i got home and ant fgure it out. i checked to fuse it was good. the passenger side window rolls up and down fine. and i couldnt find a wiring diagram in the manual so that i could jump the wires that i need to to eliminate the switch from being the problem. so if anyone has and ideas about what the problem might be or if you have a wiring diagram so i can do some more troubleshooting. it would be much appriceated. oh i the truck is a
1990 f150 4x4 4.9L 5spd manual, single cab with power windows and locks.
Hi Jared,
as you discribe the malfunktion I think it is the switch. maybe it loose the ground contact. Switch betwin up-and down position and hear ist there is some noise from the windows motor, maybe the window clips. I don't know how i can attache a wireplan but if you will give me a email add. i will send it to you.
best regard
Winfried
does anybody else have any ideas, i need to get this fixed asap. raining in my area cant go driving around in the rain with it down. can any body post the diagram of the power windo switches so i can figure this out quicker
