Engine stumbling!! Self test codes HELP PLEASE!!
Old Feb 26, 2007 | 06:27 PM
fordman16b's Avatar
fordman16b
Cool Engine stumbling!! Self test codes HELP PLEASE!!
My truck is not runing right at all. It's terrible, it stubles and studders once it warms up. It's sounds like it's missing. Also when I relly get on the gas it backfires in the exhaust. It's a 91 F150 302, 5spd, dual exhaust o2 bung in h-pipe. It's been running fine for a while (no problems), and then it suddenly went down hill the other day.
I got the following codes (Key On Engine ON):
29c
52c
92c
(Key on engine off):
31c
32c
33c
I know that code 29c is because I put in a 9inch rear instead of my 8.8 but that shouldnt be causing the problem.
Could the oxygen sensor be bad. It only has 20,000 miles on it.
I checked ACT, ECT & MAP sensors. I also swapped out the ecu for a similar one, no changes. I also checked the fuel filter.
It's eating gas like crazy.
Any help is greatly appreciated !! Thanks -Mike
Old Feb 26, 2007 | 07:17 PM
fordman16b's Avatar
fordman16b
Could it be leaky injectors?
Help please!
Old Feb 26, 2007 | 07:25 PM
Popa Tim's Avatar
Popa Tim
You can't get a 33 with KOEO.
It sounds like you have some vacuum leaks to hunt down. EGR valve & related might be a good place to start.
KOER (Engine Running) Was it warmed up when you did this? IF it was then it you'll need to resolve vacuum leaks before you troubleshoot the Rich problem imo.
Check your fuel pressures if you can.
Old Feb 26, 2007 | 07:44 PM
fordman16b's Avatar
fordman16b
I checked all the vaccum lines. No leakes. The engine was warmed up plenty.
Old Feb 27, 2007 | 04:33 PM
jle70's Avatar
jle70
I would say it could be timing chain slack. Disconnect timing spout so computer can't control timing and if you have timing light, reset timing (it will say under hood factory timing). Run the engine for a while to warm up before setting timing. After it is set take it for a drive with the spout still disconnected. Then put spout back in, take for a drive. If it runs better without spout after timing reset, the computer is trying to compensate for timing change. This is how eliminated electrical vs mechanical. And it was my timing chain slack. Not to say there isn't alot of other things that could cause your problem, but this is a quick easy check.
Old Feb 27, 2007 | 08:19 PM
fordman16b's Avatar
fordman16b
The engine only has 20,000 miles on it. I checked the timing when the engine was warm with the pip out, and the timing was dead steady.
Still trying to figure this out. Thanks for the help so far.
Old Feb 27, 2007 | 11:27 PM
dado150's Avatar
dado150
I have a 95 f150 302 4x4ex cab w/149,000m. Just changed plugs, wires,rotor, cap, fuel filter and still get the same as the rest-sshudder after it warms up-like it is loading up. My buddy is putting it on a scope to check codes, but his first guess is mass air flow valve/sensor. He says from what I told him it sounds as if it is getting to much gas! Will let ya know.
I posted this on an old post that I didn't see the date on so sorry if it is repetitive
mary-kate
17
Sep 20, 2009 11:41 PM
striker_wvu
May 20, 2008 08:35 AM
illuzion
1978 - 1996 Big Bronco
Sep 18, 2005 05:18 PM
4xfordbronc
Oct 5, 2004 03:17 PM
HwyTravler
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 29, 2004 10:45 PM
