Rotissare
Old Feb 26, 2007 | 04:33 PM
NDspeed's Avatar
NDspeed
Rotissare
so i was thinking i would sure like an easier way to work on the truck.
a simple search on a hot rod site i found this guide to building your own rotissaire.
has anyone here built one of these before?
http://members.tripod.com/~mopar_roa...otisserie.html
Old Feb 26, 2007 | 04:38 PM
NDspeed's Avatar
NDspeed
body rotisserie, augh i hate spelling things
Old Feb 26, 2007 | 04:42 PM
himmelberg's Avatar
himmelberg
Cast your eyes toward Hueytown Alabama and the inimitable John Niolon, King of the Full Beef Rollover.
Old Feb 26, 2007 | 04:54 PM
Fomoko1's Avatar
Fomoko1
Yes, I have alot trouble with that word too.
I built one for the frame and one for the cab rust repairs, to me it`s the best way to weld up a front frame clip and also to repair rusty inner/outer cab corners and sections of the floor especially with butt welding.
Old Feb 26, 2007 | 05:12 PM
LEckart's Avatar
LEckart
Also look in the gallery for fatfenders56. He built a framework that allows him to roll his cab to get the the other sides.
Old Feb 26, 2007 | 06:37 PM
56panelford's Avatar
56panelford
Check out http//www.harwoodperformance.bizland.com/ this is the one I was planning to build, I also have the one you mention in my favourites but this one I mentioned is engineered to hold a 5000 lb vehicle more than you'd want to have rolling around in your shop.
John
Old Feb 27, 2007 | 10:21 AM
lightning60's Avatar
lightning60
Any idea what a 57-60 cab weighs completely stripped down?
Old Feb 28, 2007 | 03:43 PM
jniolon's Avatar
jniolon
old and in the way
Paul this one is identical to the one I have... I'd recommend using thick wall tubing for the two end sections... there is a good deal of strain on them when loaded... mine works great and you can see parts of it on my page http://jniolon.clubfte.com
later
john
Old Feb 28, 2007 | 11:40 PM
NormH's Avatar
NormH
Two of us lifted my '56 cab up but it took four to move it very far. I guess the strip weight was around 300 lbs.
Old Feb 28, 2007 | 11:47 PM
BluegrassMan's Avatar
BluegrassMan
Guy's:
I was going to build my own, I went to the Streetrod Nationals in Louisville Ky; I bought one there for $630 show special. I don't think I could have gotten the steel and put my time in it for 600 bucks. The guy that makes the rotisseries is in Indiania, he goes around to all events. He said it would hold a 59 Caddy, I figured it would hold my 47 Ford coupe.
Old Mar 1, 2007 | 09:07 AM
Scott123's Avatar
Scott123
A show I went to here a guy had a car frame with an engine stand bolted on each end so he could do sandblasting and painting on it. Was a pretty clever and relatively cheap setup (he said he just used the $30-$40 Harbor Freight engine stands). Had the engine attach points bolted to a plate of steel that he then bolted to the end cross members of the frame. Probably not nearly strong enough for a whole body, but for just a frame it looked pretty good.
Old Mar 1, 2007 | 09:22 AM
BluegrassMan
Engine Stands
Yeah, that would work for a frame, I've seen small bodies (Model A, 37's) I think anything larger would be stretching it. A good engine stand says 1000lb limit. You could try doing that for a frame.
I took a bunch of pictures of a buddy's home made rotisserie, I could send them to you, since I bought one, I don't have any need for the pictures.
Old Mar 1, 2007 | 02:25 PM
Fomoko1's Avatar
Fomoko1
The quicker and the cheaper the better, it`s pretty much a one shot deal for most of us.
At least that`s what I`m hoping it is for me.
Old Mar 1, 2007 | 04:46 PM
mechmagcn's Avatar
mechmagcn
Here's apic of the stand I built for cab repair.
Old Mar 1, 2007 | 05:01 PM
Fomoko1's Avatar
Fomoko1
This is a great shot and similar to my cradle except I mounted the cab by the cab mounts.
It`s not easy to do mount it that way but it did save showing off my lack of body work skill.
