Bad shuttering
Old Mar 3, 2007 | 11:15 AM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
Someone posted on here that a sign of ineffective Friction Modifier is the famous TC shudder problem. Like the transmission is telling you it needs service. Dont know that from experience though. The dealer did some adjustment on my shudder problem and it went away.
Old Mar 12, 2007 | 07:51 PM
rockstate45's Avatar
rockstate45
Hey guys, I've got some bad news. My transmission shudder is coming back. Seems to be about as strong as it was before I put that Dr. Tranny modifier in there. I have another tube of it and I might try dumping it in after Spring Break. Thought I'd check back with all of you to see if you have any suggestions.
-rockstate
Old Mar 14, 2007 | 08:02 AM
superpelly's Avatar
superpelly
I have the same problem. Tried Dr tranny did not help. I did flush the tranny and then added Dr tranny. I did read a thread, that it maybe a rear-end problem and they have these kits that they sell for the fix. I will try to find this thread and post it. I don't know bad your shutter is, but when i'm towing my ATV's up a hill (on a hwy going 65mph) My truck goes into this horrible
noise, my front starts to shutter, i have to get off the gas and slowly accelerate the gas pedal. The groaning, grinding or whatever noise you call it sounds like its always coming from the tranny area.
Old Mar 15, 2007 | 12:01 AM
yardbird's Avatar
yardbird
A bad coil pak or spark plug will feel just like a trans shudder.
The shudder when pulling up hills and the speeds you are talking about sounds more like a mis-fire under load than trans shudder.
Old Mar 16, 2007 | 09:27 AM
Jimmygunz3's Avatar
Jimmygunz3
Originally Posted by superpelly
I have the same problem. I did flush the tranny. I did read a thread, that it maybe a rear-end problem and they have these kits that they sell for the fix. I will try to find this thread and post it. I don't know bad your shutter is, but when i'm towing my ATV's up a hill (on a hwy going 65mph) My truck goes into this horrible
I have the same problem but I didnt use Dr. Tranny. I used mobil 1 fluid, I was also told that the speed sensors could be bad or have alot of metal shavings with the oil stuck to it.My next step is I am going to take the sensors in the rear, and the 2 in the trans out and clean them off. Hopefully this will work.
Old Mar 16, 2007 | 09:52 AM
rsylvstr's Avatar
rsylvstr
are you sure it's the tranny and not the rear end???
throw some friction modifier in that too.
Old Jan 14, 2008 | 03:31 PM
MSB6's Avatar
MSB6
My expy has the same problem. The shuddering used to go away after a fluid change. Now it is pretty much constant. Back to the #4 coil pack misfire. Wouldnt I be getting a check engine light with a misfire?????? Help, I am about to dive into a t/c change!!!
Old Jan 15, 2008 | 09:07 AM
01expedownr's Avatar
01expedownr
was your shudder at light throttle or under acceleration? (heavier throttling)??? mine is under light throttle and mostly when im coasting or going down a long gradual decline.... it sorta starts to chug....? more input please...
Old Jan 15, 2008 | 10:57 AM
MSB6's Avatar
MSB6
It sort of started under light acceleration going up a hill and now it will do it on level ground under light acceleration. I just don't know if the T/C has given up or this has been a total misdiagnoses. I noticed when I parked it the other day the tac was fluctuating up when the shuttering was happening. I would assume if it was a misfire the rpm's would drop not go up. I had Autozone pull the codes and none were present, but they use a cheap scanner. I am hesitant to drive the vehicle in case the t/c is ready to let go. I don't want it to take the entire tranny with it!!!
Old Jan 15, 2008 | 02:06 PM
01expedownr
MSB6 are we are driving the same truck? i am having the exact same thing happen, no codes, shutter, tach wierding out, and all these posts seem to conflict.... except im driving mine.... if i shoot the tranny out the back end ill let you knwo, till then i have no other ride so i have no choice..... let me know if you find out anything on the real fix.... 01expedownr
1977cutcher
2004 - 2008 F150
53
Mar 22, 2018 09:31 AM
Phantomz
Nov 29, 2016 05:11 PM
Theholler
May 28, 2016 04:18 PM
Johnny Bravo 45
Oct 11, 2013 11:52 AM
pomial
Jul 13, 2008 11:35 PM
