accessories don't work on "accessory"
Sep 25, 2002 | 02:35 PM
The power windows, door locks, etc don't work when the ignition switch is turned to accessory... only in the on position. Any ideas?
Tom
Sep 25, 2002 | 02:42 PM
The windows won't work withou the key in ON.
The door loacks should work without the key at all.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Sep 25, 2002 | 02:48 PM
My mistake, door locks was a bad example. So the windows, radio, etc only work in the on position.
I've had many Fords including 84, 87, 89, 90, 93, 94, 97 and the windows all worked in the accessory position.
Sep 25, 2002 | 04:13 PM
So what year is the one you're talking about?
[/font]
Sep 25, 2002 | 06:02 PM
I am pretty sure you ignition switch that controls the supply of juice to options as well as to run or start has gone bad. Not the key switch itself but the module down the column that is linked (with a rod?) to the key switch. Wasn't there a recall for fire risk a few years back?
'88 302 AOD Bronco, Grant wheel, junk '31 tires for now,JVC remote CD,
Sep 26, 2002 | 09:10 AM
You may have nailed it!
I called Ford and recall 95s28 applies to Broncos... faulty ignition switch and my Bronco has not been fixed.
Heads up - it's a safety recall - could possibly cause a fire. Any Ford / Lincoln / Mercury dealer will replace affected vehicles free of charge.
I don't think the windows are supposed to worrk on "acc," but the radio should.
Sep 26, 2002 | 09:14 AM
Yes, the windows should work on acc.
Sep 26, 2002 | 11:30 AM
I never actually tried them, I know many other vehicle's windows don't work on acc. I will try mine today.
Sep 26, 2002 | 03:47 PM
pineconeford
May 14, 2014 06:56 PM
4dgrl
Sep 6, 2012 12:38 PM
tom2004
2004 - 2008 F150
Aug 20, 2010 10:57 PM
sierraben
Jan 8, 2006 09:23 AM
