Full Wireing Harness Upgrade
Old Feb 26, 2007 | 02:11 AM
acc2828's Avatar
acc2828
I have a 77 F150 and plan on doing a full restoration with some up grades. I want to install power windows and door locks with full remote entry. Up grade the sound system, and make the front clip tilt. I had already planned on a new harness, but should I use a heavier gauge harness or just heavier wires for the custom items. Thanks AL
Old Feb 26, 2007 | 12:40 PM
Franklin2's Avatar
Franklin2
If you can find a new stock harness, you will have to add a lot of extra wiring for the accessories you want to add. You may want to look at an aftermarket harness like ron francis or painless. They may have the wiring already there for the power accessories.
If you are planning on making your own harness, I would just copy the wiring for the stock items, and plan the wiring size for each component you are going to add. So you will need the power requirements of the new components like the windows, amplifiers in the sound system, etc, so you can run the correct size wire.
Old Feb 26, 2007 | 11:43 PM
acc2828's Avatar
acc2828
Sounds reasonaable. I figured I would probably need to go with a bigger fuse panel for the other accessories that I add on. And I'm thinking a bigger altenator. is that painless a harness that one of the FTE site sponsors carry? Thanks for the Help AL
Old Feb 27, 2007 | 12:41 PM
Mil1ion's Avatar
Mil1ion
There is a better system for less money than painless.plus they have excellent service as well.
try here.
www.centechwire.com
Old Feb 27, 2007 | 05:35 PM
jimdandy's Avatar
jimdandy
Call this company:
It's a Snap 1-866-462-7628
You will not believe their prices. I have used their wiring systems several times without any problems, and exceptional tech help. jd
phurst
Feb 1, 2018 11:27 AM
NWO_diesel_nut
19
Mar 22, 2014 07:57 PM
mary-kate
17
Sep 20, 2009 11:41 PM
sedly
Feb 18, 2008 09:37 AM
