Gaskets question..
Old Feb 26, 2007 | 01:03 AM
Jrock909's Avatar
Jrock909
Gaskets question..
Okay, wow since I bought a set of GT40 iron heads and a GT40 explorer intake setup I was told that I need to buy a Felpro 1250 or 1262 gasket set, that being said because I need to block off the egr ports on the heads and I am not going to use a EGR valve so the kit is suppose to have some gaskets to block off the ports. Now would a 93 Cobra top end kit have those EGR blockoff gaskets?
Old Feb 26, 2007 | 05:09 AM
HemiEater's Avatar
HemiEater
most intake sets will have them
Old Feb 26, 2007 | 10:01 AM
Conanski's Avatar
Conanski
The Explorer intake has no EGR port so it'll be blocked off no matter what gasket you use.
Old Feb 26, 2007 | 01:19 PM
Jrock909's Avatar
Jrock909
Okay so you are right Conanski I looked on my lower intake and didn't see EGR port in the middle of the intake. Now what gasket set would I have to buy to get all the gaskets that I would need. The Cobra set should be fine I would think even though it would probably have the hole for the egr port, but even though there isn't no hole on the lower intake I could still use that gasket don't you think?
MR KROGOTH
23
Mar 27, 2017 09:45 PM
EllieMae94
Jan 17, 2017 10:55 AM
cd4e
Oct 28, 2016 06:11 PM
Bowers25
16
May 26, 2016 08:11 AM
jaagen
Apr 27, 2016 05:24 PM
