newbie has tachometer probs..
Old Feb 25, 2007 | 11:04 PM
xjvince's Avatar
xjvince
Unhappy newbie has tachometer probs..
at times my tach dont work or it will twitch around. then it will be fine for a while. where does it get its sgnal? what should I look for? I'm still learning what everything is under the hood.
I have a 94 IDI NA 5spd
thanks, Vince
Old Feb 26, 2007 | 02:22 AM
dwaymar's Avatar
dwaymar
tach sensor on timing cover looks like a big nut with wires coming out of it
Old Feb 26, 2007 | 03:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
this is your tach sensor.
there is a plug up the wires a bit. check the plug for a tight fit.
http://i41.photobucket.com/albums/e261/tjctransport/tachsensor.jpg
Old Feb 26, 2007 | 04:32 AM
PLC7.3's Avatar
PLC7.3
Quite often the wire covering will pull back out of the tach sensor and the wires will touch causing intermittent readings........
Ford only part Engine RPM sensor E5TZ-17B384-A about $50.
Old Feb 26, 2007 | 08:20 PM
catfish101's Avatar
catfish101
The tach gets it signal from the injection pump drive gear. It is an analog signal. You can also check buy taking your sensor out get somebody to take a chishel or a screwdriver and swipping it across the sensor tip pretty fast. Get somebody to watch the tach while you wiggle the wiring around. You need to have the key on. If you are alone use a mirror and wiggle everything around while you swipe a iece of metal across the sensor..
Old Feb 26, 2007 | 09:09 PM
xjvince's Avatar
xjvince
thanks for the info, everybody. i'm gonna check it out first thing in the morning.
Vince
Old Mar 5, 2007 | 08:25 PM
jcruth's Avatar
jcruth
well now i know what that big nut with the cut wires is. and why my tach dont work. first diesel had it a week, drove home fine, hasnt run in a week,but im learnin and i got it to run for 30- 40 sec today..woot!!
Old Mar 7, 2007 | 07:49 PM
rockcrawlerdude's Avatar
rockcrawlerdude
just replaced mine and the tach and the tranny now work fine...
Old Mar 8, 2007 | 10:04 AM
xjvince's Avatar
xjvince
aftermarket or Ford? what price? the wires on mine are shot.
Old Mar 8, 2007 | 10:24 AM
rockcrawlerdude
ford and $60 at the dealer....
