1978 - 1996 Big Bronco
Front end lift
Old Sep 27, 2002 | 10:18 AM
fast_eddy's Avatar
fast_eddy
Front end lift
Old Sep 27, 2002 | 03:47 PM
Bronco AR's Avatar
Bronco AR
Front end lift
I just bought my first bronco - a 90 model with a 5.0 and a warn winch with grill & brushguard ($2400). I notice that the front end seems lower than the rear, and would like to correct the problem. I have seen "leveling" springs for sale. Is this the best way to fix the problem? They are supposed to lift it about 1 1/2" I believe. I was thinking that F250 springs might work, too. Does anyone have any advice? I plan on putting 33's on when the current tires wear out (if they fit), but right now I want to level it out.
Old Sep 27, 2002 | 04:21 PM
bronco cam's Avatar
bronco cam
Front end lift
Yes they have a 2inch leveling lift for the front that is not very expensive. Even with out the winch fords sit low in the front
Old Sep 27, 2002 | 04:40 PM
Pioneer Ford's Avatar
Pioneer Ford
Front end lift
you might want to check jc whitney for spring spacers. They usually sit on top of your existing spring and lift about 1 inch or so. It's a cheaper option if you consider it, although I have never tried them. Good luck
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
