won't start
Old Feb 25, 2007 | 06:25 PM
01f-350dually's Avatar
01f-350dually
won't start
Hello all, I have an 01 f-350 7.3 psd 4x4 that won't start unless it is plugged in.
The temp today was 43 degrees, I understand that when it is cold that it is hard on it, but 43 degrees? I do have it chipped, exhaust, and the intake done. Any Ideas what is wrong? My first thought is the fuel heater but thought I would ask someone who knows!
Old Feb 25, 2007 | 06:32 PM
Uzumati's Avatar
Uzumati
My guess would be glow plug relay. Jump the two large post with a screwdriver for 30 seconds before you start next time.
Old Feb 25, 2007 | 06:33 PM
01f-350dually
did I mention that I have no idea what I am doing, I'm new to this!
Old Feb 25, 2007 | 06:40 PM
Uzumati's Avatar
Uzumati
Next to the fuel filter housing under the "Powerstroke Cover" are two relays, the one closest to the windshield is the Glow Plug relay. The glow plugs are energized at key on and stay on up to 2 minutes to warm the cylinders. A bad one will cause hard starts in the cold.
powerstrokin007's Avatar
powerstrokin007
When you say "plugged in" do you have battery blankets or oil pan heater. Before you start it can you hear the glow plug relay click. Not sure why you would have to plug it in to get it to start. Not sure if it going to be the glowplug relay.
Old Feb 25, 2007 | 06:48 PM
01f-350dually
It must be a pan heater? there is nothing around the batteries. And I can hear a click
Old Feb 25, 2007 | 06:52 PM
Uzumati's Avatar
Uzumati
If it stock it is the block heater you are plugging in.
Old Feb 25, 2007 | 06:54 PM
01f-350dually
ok, Thanks!
Old Feb 25, 2007 | 07:03 PM
powerstrokin007
Strange that you have to plug it in at 43 degrees. I have no block heater, pads or blankets and mine had no problem starting when it's -15 degrees in Alaska.
Old Feb 25, 2007 | 07:06 PM
Uzumati's Avatar
Uzumati
That is because your glow plug system is working powerstrokin007.
01f-350dually
Thats what I'm talking about, In the past it has always started no matter what temp
Old Feb 25, 2007 | 07:17 PM
01f-350dually
Thanks for your help amiller93!
Old Feb 25, 2007 | 07:19 PM
01f-350dually
What is the second relay for? Closest the the fan?
Kwikkordead's Avatar
Kwikkordead
In most cases your problem can be diagnosed in the way that Amiller is describing. Jump the two big posts on the glow plug relay for 30 seconds and then attempt to start it. If it's a failed relay, it will start immediatly.
Old Feb 25, 2007 | 07:20 PM
powerstrokin007
Yes but in extreme cold it's nice to have blankets around the battery so they don't freeze and a pan heater to warm up the oil for better circulation. Try this, when you go out and start your truck, cycle the glow plugs, turn the key off, then cycle the glow plug again, then try starting it to see what it does.
