Fan Shroud Question
Old Feb 25, 2007 | 08:28 AM
mlaymance's Avatar
mlaymance
Fan Shroud Question
my '93 F-150 I-6 Auto 2WD
does not have a fan shroud. Is this something that is missing?
If so what other models will fit. Would like to get one to put on it
if it came from factory equipped with one.
It shows no signs of overheating, more of a safety issue than anything else.
I can envision accidentally dropping a a wrench into the fan, uhhhhhhhhhhhh that was not a pretty sight!!
Thanks for all the help guys, the forum is great. Lots of expertise here!
Michael
Old Feb 25, 2007 | 11:36 AM
92F150Flare's Avatar
92F150Flare
hi and welcome.......i'm kind of new too......what part of SC?.....I'm in Goose Creek.
yep....it should have a shroud.......you can probly use one from the years indicated in this forum......87-96.......but i'm not sure of that. Your local boneyard will tell you which years match up and probly have one you can put on. Usually do have some overheating problems without one......specially here in SC
Good luck
Old Feb 25, 2007 | 12:27 PM
mlaymance's Avatar
mlaymance
Flare,
here north of Spartanburg in Blacksburg. Thanks for the info. will look for one.
Thanks,
