ccv mod Fire starter
Old Feb 25, 2007 | 12:14 AM
hedhntr's Avatar
hedhntr
I installed the ccv mod similar to guzzles. After 10 feet of heater hose I put a 12 inch piece of pvc pipe with holes drilled all around it. I filled it with cheese cloth so I wouldnt be dripping any oil on the pavement. My question is would it get hot enough to start a fire
Old Feb 25, 2007 | 12:18 AM
hosemandc's Avatar
hosemandc
It won't get that hot. If it does I would think you have serious issues with your engine.
Old Feb 25, 2007 | 01:21 AM
jtharvey's Avatar
jtharvey
You are fine. The vapor coming out of that hose will have plenty of time to cool down before it hits the cheese cloth. It's probably not all that hot coming out of the engine anyway.
Old Feb 25, 2007 | 01:39 AM
John311t's Avatar
John311t
I have mine just laying towards the ground by the front u-joint on the front driveshaft, and i do not think i have ever seen oil on my driveway from it.
Old Feb 25, 2007 | 07:09 AM
Uzumati's Avatar
Uzumati
With the engine running I can put my hand right up next to the outlet and it is no warmer than ambient air with 10" of hose.
