The 1211 code
Old Feb 24, 2007 | 10:31 AM
John311t's Avatar
John311t
The 1211 code
I while back i posted about how my truck had the dreaded code. I was going to check the pressure with a gauge that went to 6000psi i had but then i got the AE and decided to see what it was. No wonder it kept pulling that code, the pump cannot get over 1800PSI, it did once at a shift spike it shot up to 3200PSI. Thats with the EVO on Extreme. Now my question is, with the reman 17degree pumps i thought i read that they were a hit and miss? I cant see much being worse than mine, im going to try it with my truck on stock, but i could not get it over 1800 until it had one shift spike, that i could not reproduce the rest of my drive.
Old Feb 24, 2007 | 06:03 PM
Uzumati's Avatar
Uzumati
John look at two PID's Injection control pressure (ICP) and Injection control pressure duty cycle(IPR). Write down or datalog this test.
In Park/Nuetral with Parking brake set
Get ICP and IPR duty cycle at idle
Hold Truck at WOT for 3 minutes get ICP and IPR DC at start
Get a couple of readings during the test and at the end, also note the Highest and Lowest values for both sensors. ICP should not fall below 1800 and IPR DC should not go over 65%
Old Feb 24, 2007 | 07:08 PM
zx250's Avatar
zx250
Of the next Riffraff East
Just went through the 1211 code thing and thanks to amiller93 and others here I think I have it fixed. Here are my post and what I went through, Maybe it will help.
https://www.ford-trucks.com/forums/5...-my-truck.html
https://www.ford-trucks.com/forums/5...ore-ideas.html
Turned out to be my IPR was bad. I rebuilt and cleaned it. It must have been damaged. It did pass the 65% test once, but not the second time.
Old Feb 24, 2007 | 10:24 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Dang man that early pump sucks. Do the early 99 trucks have a 15* swash? Either you have some really hot tunes or a weak pump! I am thinking weak pump. I can't afford AE and a Laptop along with the other things i want more than that, so im rigging up a permanent gauge setup.
Old Feb 25, 2007 | 12:58 AM
John311t's Avatar
John311t
Yup, its the 15*. It sucks. I dont think the evolutions tunes are that hot so im guessin the pump is just extreme weak since i have pulled that code on stock before. Im going to hopefully take it for a drive tommorrow on stock and see what the pressures are then im going to do the diagnostic method alan mentioned. I got a small 0-6000 psi gauge if ya want it.
Old Feb 25, 2007 | 07:17 AM
aklim's Avatar
aklim
Why rebuild as opposed to replacing it? How much did the part cost?
Old Feb 25, 2007 | 07:32 AM
Uzumati's Avatar
Uzumati
IPR from Ford 311.50
From Millineum Ford 186.90 http://www.trademotion.com/partlocat...?siteid=214072 part number F81Z-9C968-AB
Ebay's about the same as Millineum
Rebuild http://cw-diesel.com/LuxSite/IPRInfo.htm
