Sponsored by: Real Truck
Strange turn signal problem
Old Feb 24, 2007 | 08:29 PM
swanee's Avatar
swanee
The other night I made a rather abrubt stop and right after that noticed the left turn signal blinks really fast. I must have knocked something out of whack. So my question is can I change out the blinker like you used to be able to do in older vehicles, or what? Thanks.
Old Feb 24, 2007 | 08:40 PM
cdrmotorsports's Avatar
cdrmotorsports
Is it just your left signal? Have you checked to make sure that one of your turn signal bulbs has not burned out?
Old Feb 24, 2007 | 08:43 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Gotta check both front and rear!
Old Feb 24, 2007 | 08:45 PM
Joms's Avatar
Joms
Sounds like either a burnt out bulb or it got loose in the socket.....try taking the bulb out and putting it back in tight?
Old Feb 24, 2007 | 08:47 PM
swanee's Avatar
swanee
All lights are operational. It is the left only, the right works normally. It looks like a strobe light. The only thing I did not check is what happens with the hazzard lights.
Old Feb 24, 2007 | 09:25 PM
redford's Avatar
redford
FTE Leadership Emeritus
Blinking at a fast rate USUALLY means you have a burned out light bulb somewhere.
Old Mar 1, 2007 | 04:45 PM
davhut's Avatar
davhut
You've got a bulb out (front or rear - left side) or loose in the socket. I've been down this path beofre a few times with my 2000 PSD SCREW. In my case, bulb loose in socket - had to pull it and pry clips in socket together a little more. It's either loose/blown bulb or a wiring fault doing the same thing.
Old Mar 1, 2007 | 07:10 PM
PHWLEE's Avatar
PHWLEE
Happened to me recently. Yeah, the fast blinking relay means a burnt bulb on the side it is blinking fast. In my case it was the rear right. Bulb looked good but was actually bad, so I replaced the bulb and everything is all good again.
Killgore
15
Jan 14, 2014 04:25 PM
mikeismadness
1978 - 1996 Big Bronco
Apr 11, 2010 12:05 AM
deficientblair
2004 - 2008 F150
Dec 19, 2009 01:07 AM
mdjwahl
1997 - 2003 F150
Jul 18, 2007 09:50 AM
jbs03ranger
Jun 7, 2007 08:28 PM
