Aftermarket Products
Sponsored by: Worksport
remote start stopped working properly
Old Feb 24, 2007 | 12:37 PM
softail250's Avatar
softail250
<TABLE class=tborder id=post4636411 cellSpacing=0 cellPadding=6 width="100%" align=center border=0><TBODY><TR vAlign=top><TD class=alt1 id=td_post_4636411><TABLE cellSpacing=1 cellPadding=1 align=right border=0 valign="top"><TBODY><TR><TD>******** language=javascript><!--document.write('<scr'+'ipt language=javascript src="http://a.tribalfusion.com/j.ad?site=AutomotiveForumscom&adSpace=CustomCampai gn&size=300x250&noAd=1&requestID='+((new Date()).getTime() % 2147483648) + Math.random()+'"></scr'+'ipt>');//--></SCRIPT>******** language=javascript src="http://a.tribalfusion.com/j.ad?site=AutomotiveForumscom&adSpace=CustomCampai gn&size=300x250&noAd=1&requestID=19628085700.59192 48496142171"></SCRIPT><CENTER></CENTER><NOSCRIPT> </NOSCRIPT></TD></TR></TBODY></TABLE><!-- TF 300x250 JScript NoAD code -->Hey guys, hopefully someone can help me out here. I had a remote starter installed in my '02 f250 right after I got it ( late 2001 ). It has worked flawlessly until yesterday. I was messing around with it at a buddy's house and I believe I may have accidentally possibly reprogrammed it....or maybe even wiped out its program somehow. Let me try to explain what I did. My buddy had locked his keys in his f-250 while it was running, and I told him that my truck wouldn't let me do that , and proceeded to show him how my lock would unlock itself if I tried to lock the door with the switch on the door while my truck was running ( I knew my truck did that, but it was the first time I actually tried it). Anyway, after I messes around with the remote button a few times, I noticed that I could no longer keep my truck running and remove the keys like I should be able to. The key fob still works....kinda.....when I press the lock and unlock buttons...the doors lock and unlock just like they should....but.....now when I do this I get a horn beep when the locks go up and down...didn't used to do that....I used to only get the horn beep if I pressed the button a second time, like a confirmation beep. When I press the remote start button I get two quick beeps, but it doesn't try to start. I used to get one beep....then it started. If it makes a difference, the "panic" button still does what its supposed to. I've already tried disconnecting the truck's batter for about 10 min......didn't fix it. I don't remember the brand name of the remote starter that I had installed, but the fcc ID on the key fob is goh-four, and I believe it's made by Code, I found a replacement remote online that looked exactly like mine, and it was labeled as a Code replacement fob. Sorry I was so long winded, hope I explained myself clearly enough that somebody can point me in the right direction.
<!-- / message --></TD></TR><TR><TD class=alt2><!-- BEGIN TEMPLATE: postbit_onlinestatus --> <!-- END TEMPLATE: postbit_onlinestatus --> </TD><TD class=alt1 align=right><!-- controls --></TD></TR></TBODY></TABLE>
Old Feb 24, 2007 | 07:42 PM
Joms's Avatar
Joms
Hmmm....this might be a long shot but try replacing the batteries in the key fob. Sometimes the better remote start units send a signal back to the truck to tell when the battery is low and causes an extra beep or something like that. It could have something to do with it not starting as well....Just a thought. Hopefully someone will jump in that knows more about these things...
Old Feb 25, 2007 | 12:57 PM
softail250's Avatar
softail250
Unfortunately replacing the battery in the key fob didn't do the trick, it was worth a shot though.
Roy Morgan
Jul 25, 2010 09:44 PM
kawa
1983 - 2012 Ranger & B-Series
Nov 18, 2009 04:11 AM
offroader1994
Dec 3, 2008 09:24 PM
donny3369
Dec 3, 2008 08:13 PM
BIG-COUNTRY
Offroad & 4x4
17
May 4, 2006 09:21 PM
