1978 - 1996 Big Bronco
Electric Cooling Fan
Old Aug 20, 2002 | 09:43 PM
88BroncoXLT's Avatar
88BroncoXLT
I have replaced the fan clutch twice and both of them sound like an air plane taking off and My MPG has fell to about 9.5mpg . They never stop pulling even at 70mph. I need to know if I put a 16 inch aftermarket fan kit on this (88-351-c6) if it will cool it. It stays now on the O or R in Normal. After sitting for 20-30 min it will climb up to the M.
Thanks
Chris
Old Aug 21, 2002 | 01:58 AM
Riso79's Avatar
Riso79
I have found that if you do not use a Ford factory fan clutch you will usually have a problem. As far as the electric fan goes, I dont think that 1 fan is enough. Flex-a-lite makes a dual fan set up that works great. I had it on my 93 w/ 351 and it kept the temp gauge where ever I set the thermostat at. I noticed a huge difference in acceleration and gas mileage. The car ran quieter and more responsive at highway speeds. The main thing you need to be carefull of is where you mount the thermostat box, mount it away from the radiator and as far as you can from heat.
Old Aug 21, 2002 | 08:47 AM
fast_eddy's Avatar
fast_eddy
Depending on your area, and how hot it gets, even the dual electric fans may not provide enough cooling. I have seen several users (from southern areas, mostly) post that their electric fans just didn't cool as well as the stock fan.
Old Aug 21, 2002 | 09:01 AM
TheGreep's Avatar
TheGreep
Have you thought about getting a flex fan? I think they cool better, without seriously affecting the performance of the engine.
1992 Bronco Eddie Bauer: K&N, Magnaflow Exhaust, too much money in stereo equipment, 33X12.50 tires on stock suspension. Check it out: [link:aries.ccicom.com/truck|My Fat Truck]
Old Aug 21, 2002 | 09:34 AM
adelyser's Avatar
adelyser
I put a flex-flan on my '88 F-150 with the 302, and it worked great. I never had a cooling problem, it increased throttle response, doesn't need a clutch, and sounds cool when you rev them up! If the clutch goes bad in this Bronco, I will be putting a flex fan in.
Old Aug 21, 2002 | 09:39 AM
georgedavila's Avatar
georgedavila
If you live in an area with extreme summer temps, aftermarket electric fans won't cool it. And stock fans with a shroud are superior to flex fans. The Lincoln LS fan will do it, 5000+cfm, as will late (94-96) Taurus electric fans. Both have big amperage appetites to achieve their cfm abilities, with the Lincoln requiring 80amps initial and 35-40 on a steady basis.
Get a real gauge. You don't actually know what your operating temps are with the stock resistor type gauge.
It's very possible to get two defective fan clutches in a row.
Old Sep 19, 2002 | 05:59 PM
cwade3's Avatar
cwade3
[updated:LAST EDITED ON 19-Sep-02 AT 07:02 PM (EST)]hey aaron d! have you put the flex fan in your newer bronco yet? if you did, did you leave the fan shroud in and which size spacer and fan did you use. or anyone else do this mod would like any info on it ie cooling problems with air conditioner. mine is a 95 bronco with a 302 looking for increasing ponies cheaply. already rerouted coolant hoses off the throttle body and plugged the egr valve hose that helped tremendously so far no ill effects. thanks for yalls time
Old Sep 20, 2002 | 08:37 AM
adelyser's Avatar
adelyser
No, I haven't added the flex fan yet. I have come across some other repairs/mods that needed more attention. When I put it in my truck, I used the stock shroud and a flex fan that would fit in the shroud. As for the spacer, I basicall measured the height of the fan clutch and used that. It turned out it was just right.
Old Sep 20, 2002 | 10:17 PM
firedude's Avatar
firedude
Something to be cautious about when using a flex-fan. Some times when you run higher RPM's, but slower MPH, (such as mudding) The flex-fan will flatten out and not draw enough air through the radiator. They are designed to flatten out somewhat at higher RPM/speeds thereby not drawing down the horsepower. Allowing the utilization of ram-air to dissipate the heat in the radiator.
Old Sep 21, 2002 | 10:48 AM
cwade3's Avatar
cwade3
firedude that is a good point didnt think of that, especially if you a hardcore offroader. my self most of the places i go arent very long roads or extremely muddy its just enough where you dont want to go in a 2 wheel drive. thanks for the input.
Old Oct 3, 2002 | 01:17 PM
dustylollis's Avatar
dustylollis
i had a flex fan on my bronco when i first got it back in may. of course, it did not have a fan clutch, so it ran all of the time. i pulled it and put an electric cooling fan behind the radiator so it would function as a pull fan. since i have worked on mustangs most of my adult life, i had a bright idea and put a hd cooling fan and fan clutch from a 91 5.0 stang on the front of my 351. not once, while using the air or not, has the temp gauge went above the "N". i also have stainless 160 thermostat in the neck. hope this helps.
any questions email me at dustylollis@peoplepc.com
Old Oct 3, 2002 | 01:33 PM
Big Red Bronco's Avatar
Big Red Bronco
Post Electric Cooling Fan
