View Poll Results: Should i go with the longer bodied Oil Filter?
The standard PH3766 is good enough for FORD it should be good enough for you
14.29%
GO FOR IT run the 3786 for the added benefits...
18
85.71%
Voters: 21. You may not vote on this poll
Oil Filters....
Old Feb 25, 2007 | 10:05 AM
bc6.9's Avatar
bc6.9
How can you go wrong with the P/S filter.
Dave7.3, how much are K&N oil filters? My guess is that the're more than P/S oil filter...what I'm getting at for the price of the K&N, you might be better off changing your oil at earlier intervels[?]
When I bought my first brand new car [1978 Firebird Formula 400TA 4speed] I changed the oil & Filter every 1,000 kilometers [650 miles], I didn't even drive it in the rain and I lived in Vancouver BC ......ahhh those were the days.
Old Feb 25, 2007 | 02:00 PM
Dave7.3's Avatar
Dave7.3
The K&N filters I have seen range anywhere from $10-$13. I already change my oil at 3000 mile intervals but the oil comes out black even after only a few miles on a fresh oil change. I am looking for improved filtering to try and get that stuff out, and plus the Marvel's Mystery Oil I plan to add will be breaking up more gunk so, a good filter would be best to catch it.
Thats a little extreme for car care isn't it bc6.9? LOL, what would you do if you drove it to work and it rained?
Old Feb 25, 2007 | 04:56 PM
typefour's Avatar
typefour
The anti drainback valve is for filters mounted upside down. Ours are as about as low as they can get and the oil would drain out of the main bearings anyway. Here is a query, how long does it take for your IDI to show oil pressure , mine is about 3 seconds cold. 4 or 5 warm. BTW I run the PS filter, fleetguard or napa.
Old Feb 25, 2007 | 08:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The pressure relief valve is in the oil filter header from the factory.
It is against the block when the header is installed on the engine.
Old Feb 26, 2007 | 10:02 AM
Dave7.3's Avatar
Dave7.3
Well now it makes sense, thanks guys. That clears up alot of fog around the filter topic
Old Feb 26, 2007 | 10:38 AM
PLC7.3's Avatar
PLC7.3
I use the LF 3630 from Fleetguard, your not using FRAM are ya Rockcrawler
Old Feb 26, 2007 | 12:19 PM
pwrdbyjp's Avatar
pwrdbyjp
What about the Motorcraft FL1995? Any better than FRAM?
Old Feb 26, 2007 | 12:53 PM
rockcrawlerdude's Avatar
rockcrawlerdude
well i havent changed my filter yet BUT i did buy the fram filter becuz thats what it said in the book... i did notice the other filter ( not fram) looked like it had the same mounting hole size so i wanted to see what ya'll thought about going with that one instead ( which is the power stroke one)... so what brand (power stroke) filter would ya'll recommend???
Old Feb 27, 2007 | 07:24 PM
Dave Barbieri's Avatar
Dave Barbieri
I've always had great results with Baldwin and Wix. High quality construction, great filtering ability. Filter size and micron ratings are listed below:
Baldwin
B134 23 microns 4.25” x 5.875”
B7039 12 microns 4.25” x 7.375”
Fleetguard
LF3344 30 microns 4.25” x 5.75”
LF3630 30 microns 4.25” x 8.125”
Wix
51742 25 microns 4.25” x 6”
51734 19 microns 4.25” x 8"
Technical Service Hot Line:
Baldwin
800.822.5394
Fleetguard
800.223.4583
Purolator
910.426.4363 Richard
910.426.4812 Rob
Wix
800.949.6698
Old Oct 11, 2010 | 07:16 AM
Skip1970's Avatar
Skip1970
so anyone know what the shortest filter is that will work on a idid, i could use a extra inch there on my 6.9 adn dont got the money for a remote mount.
Old Oct 11, 2010 | 10:01 AM
oreocreaming's Avatar
oreocreaming
with the idi, id suggest 3000 miles. with the psd, 5k is fine since they use 16 qts. and in my idi (pre bypass system) i ran 12 qts and kept it a quart over. and thats with the standard idi filter. nothing special.
Old Oct 11, 2010 | 10:03 AM
oreocreaming
damn, didnt notice how old the post was. you didnt need to bring up a old post like this b-uno, you already started a new thread asking the same thing and your gonna get answers from the same people.
Old Oct 11, 2010 | 02:23 PM
  #28
Skip1970's Avatar
Skip1970
ya this is old, but it had dimensions of oil filters so i wanted to comment forsure to get it saved in my usercp so i could references it later, anyone know how long a fram filter is? or do i gotta crawl under the truck again and get a measurement might as well take a pic too, u know i dont think i have a fram on it since i hate them, and this ones black.
77_150_460
Jan 25, 2010 06:14 PM
wreedZ71
2004 - 2008 F150
15
May 14, 2009 07:33 AM
BURNSTOUGHFORD
Modular V8 (4.6L, 5.4L)
33
Jan 23, 2009 07:06 AM
SeminoleSlim
25
Jul 15, 2008 10:32 PM
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
