Weird CEL prob......
Old Feb 23, 2007 | 10:05 AM
kiohio1985's Avatar
kiohio1985
Unhappy Weird CEL prob......
Ok....
Truck runs great.....but after driving the CEL comes on.
I had codes shecked, only one "HEGO running lean".
No biggie, change sensor....same thing. (old one looked good btw).
I pulled the EGR, it looks fantastic, same with IAC...
Everything on the truck look like it has lower milage on it but I know miles are correct it just spent alot of time on the highway, 70k in 3 yrs.
I can't find any vac leaks, if you drive long enough the CEL will go out.
If the truck is already warm and yo turn it off, then drive it sometimes it will stay off for quite a while, sometimes it'll come right back on in just a few miles.
EVERYTHING is stock or a stock replacement, exhaust etc.
Could a bad Cat do this? Make the sensor think it's lean?
If it weren't for the annoying CEL you'd not think anything of it.
Thanks in advance,
KO
Old Feb 23, 2007 | 08:42 PM
xltlariat87's Avatar
xltlariat87
when the o2 sensor, was changed were the codes cleared?
Old Feb 26, 2007 | 10:54 AM
kiohio1985's Avatar
kiohio1985
Yes, they were.
Then just for good measure I did it again overnight.
Still does it......irritatin' y'know
KO
Old Feb 26, 2007 | 11:53 AM
Kemicalburns's Avatar
Kemicalburns
try a ford o2 sensor. was the truck to operating temp when you checked codes. whats your timing set at?
Old Feb 26, 2007 | 12:55 PM
kiohio1985's Avatar
kiohio1985
It is a Bosch O2 sensor.
I need to look again but I think the original had FORD and Bosch on it, could that be right?
Truck had been ran 20 mins, 5 at idle then 15 into town.
Not sure on the timing. Will that cause the light to come on?
KO
Old Feb 26, 2007 | 05:28 PM
fordman16b's Avatar
fordman16b
Factory ford parts are often times made by bosch, like the fuel pressure regulator, and the o2 sensor
Old Feb 28, 2007 | 10:55 AM
kiohio1985's Avatar
kiohio1985
I thought so, but wasn't sure......
KO
Old Feb 28, 2007 | 03:53 PM
woodly1069's Avatar
woodly1069
What are the codes and how do I check and clear them?
Can you do this without some expensive tool or hand held computer? My truck is a 1994 F150 and seems to be having some of the same issues...Thanks in advance for any replies
