F-150 Poor Quality
Old Feb 23, 2007 | 08:21 AM
Scooterocket's Avatar
Scooterocket
F-150 Poor Quality
I bought new a 2004 F-150 XLT Supercab 4X4 with heavy duty everything. I've put only 7,400 miles on it. I just took it in to the dealer because the charge warning light has been coming on, I'm getting a wheel hop when turning sharp corners, and the rear sliding window stopped working. The dealer says since it's one week over the 3 year warranty, I'll have to pay for diagnostic charges, new alternator, repack of the differential, and new rear window switch. Altogether, it will cost me about $3,000 when I pick it up this afternoon. $3,000 in repairs after 7,400 miles!!! I'm very sorry that I bought a Ford. That's a mistake I'll never make again. Is it any wonder the company is going down the tubes?
Old Feb 23, 2007 | 09:23 AM
gui88ford's Avatar
gui88ford
well, if your car had all these problems and your warrenty is only one week over you should have taken it in 2 weeks ago to have everything looked at....even though i would speak to the manager and who ever i had to and i woulnd't pay it...refuse to pay it because it's only one week and you shouldn't have problems after 7,400 miles.....
Old Feb 23, 2007 | 09:26 AM
ford9c's Avatar
ford9c
Your not alone. Ford will use any and every excuse to avoid warranty repairs. You could be 1 hour over and they will try to charge you. The alternator and rear diff repairs could be done at any competent local repair facility. The rear window is a known problem with the motor corroding internally. That could get expensive. My advise is to bring it up with the warranty administrator at the dealership. Maybe you can get some relief. If not, I wouldn't give more money to ford. Give it to a deserving local independent garage instead.
Old Feb 23, 2007 | 09:37 AM
gui88ford's Avatar
gui88ford
well, my big question is i guess....did all of these problems happen after your warrenty was up....it seams a little weird to me how you have all these problems within one week of your warrenty ending????
Old Feb 23, 2007 | 09:47 AM
red dog's Avatar
red dog
what would cause the wheel hop when turning tight, just curious as my old f-250 would do that.
Old Feb 23, 2007 | 10:28 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the Limited slip, old springs, bad tires, bad shocks, bad wheel bearings, hitting the curb
lots of things. you have to put them on a lift and wiggle stuff until you find the culprit (if your lucky)
Old Feb 23, 2007 | 10:29 AM
mbogosia's Avatar
mbogosia
Yeah If you are out of warranty then I would find a good local independent shop. You probably could have had the same work done for $1500-$2000. Or, try buying the part online and instaling yourself.
Old Feb 23, 2007 | 11:53 AM
FXForistell's Avatar
FXForistell
Hmm... So all these problems sprang up immediately after the warranty expired. Odd. Otherwise you would surely have addressed the issues while it was still under warranty.
It's a well kept secret (shame on me for sharing) that Fords fall apart after 3 years or 7,500 miles. We all just drive them anyway because we have the money and the patience to deal with the constant, never ending, just out of warranty problems.
Or maybe not. Maybe you just need a place to vent because you're mad you didn't address the problems while it was still under warranty and you want to blame Ford instead of the one who procrastinated in the first place. Nah.
Old Feb 23, 2007 | 12:24 PM
Wr3ckin_Cr3w's Avatar
Wr3ckin_Cr3w
i bought my '04 used with 50k miles on it and now i have over 100k on it. and not a single problem on it
Old Feb 23, 2007 | 12:25 PM
gui88ford's Avatar
gui88ford
thats the one i'm betting on...
Old Mar 2, 2007 | 10:17 PM
mack63's Avatar
mack63
You only put 7,500 miles on it in 3 years?
Old Mar 3, 2007 | 08:03 AM
BigDfromTN's Avatar
BigDfromTN
Most likely limited slip rearend locking up, or you are driving in 4wd?????
Old Mar 3, 2007 | 09:56 AM
osbornk's Avatar
osbornk
The warranty covers problems based on the time and mileage. If you let it run out, what can you expect? I'll bet every problem you outlined was known before the warranty ran out.
Old Mar 3, 2007 | 10:21 AM
HMFX4IC's Avatar
HMFX4IC
I'm willing to bet that he doesn't even own the truck he speaks of or any FORD for that matter... Just doesn't add up. !st post too, hmmm.
Were probably waisting our time on this thread anyways. He joined and made this thread on 2-23-07 and this was also the last time he has logged back in.
Old Mar 3, 2007 | 10:39 AM
lostin90s's Avatar
lostin90s
Nope it happened to me and several of my friends . Although they all went to dodge I just buy used Ford trucks if it have over 40000 never have any problems
They Ford bit me 3 times . on new trucks 86 F150 300-6 7 MPG they wouldn't fix it.
95 F150 302 5 sp 4x4 Ran bad no power and 10 MPg If lucky. It was 3rd with 302 5sp 3:55 rears and it got way less MPG than all others. Last was a 2003 F150 kept 6 months . lots of problems ,seats sucked . Ford has not made good F150 since 96. I run 2003 F250 now its fine. But I just get truck used now. As for this guy I never take anything to any garage and don't say if you have to replace I want to know first . But your right if have problem take in that week.
