Cluster Colors
Old Feb 22, 2007 | 11:37 PM
Rollin03F250's Avatar
Rollin03F250
Cluster Colors
Does anyone know where i can find dash cluster wire colors for my 03 SD without having to buy a book of some sort. Or if haynes or any of them tell you what wire is for what application on the cluster (ie: temp, speedo, batt)
Old Feb 23, 2007 | 08:43 AM
Franklin2's Avatar
Franklin2
What are you intending to do? Your cluster is very complex with a microprocessor, battery saver relay, and communication wiring to the engine computer. There are no more wires to sending units on the engine(except the oil pressure and the fuel level gauge). The other gauges and warning lights receive their info from the engine computer by communication network.
Old Feb 23, 2007 | 10:45 AM
Rollin03F250
on my 03 tahoe i can unplug my speedo wire so that my speedo only doesnt work and it stops the mileage with everything else working on the cluster. I just dont think its the same color on my ford or if it acts the same way.
Old Feb 23, 2007 | 12:19 PM
Franklin2's Avatar
Franklin2
Your speedo works off the speed sensor input. The way I am understanding how it works, the speed sensor raw signal goes right into the instrument cluster. The instrument cluster computer processes the raw signal and drives the speedo, and also sends the new speed signal info on the network to the abs computer, the cruise control, and the engine computer.
So if you get rid of the signal, you are going to get errors on all those systems, the cruise control won't work, and the tranny won't shift correctly.
Old Feb 23, 2007 | 10:19 PM
Rollin03F250
so then whats the trick to unhooking the odometer??? somebody's gotta know...?
Old Feb 24, 2007 | 12:32 AM
Mil1ion's Avatar
Mil1ion
Isn't that against the law ?
Old Feb 24, 2007 | 12:47 PM
Rollin03F250
yeah but so is speeding, people do it everyday so what can ya do.
Old Feb 24, 2007 | 07:03 PM
tdister's Avatar
tdister
Did you happen to read this before signing on with the website?
https://www.ford-trucks.com/legal.html
/this is me being as nice as possible to someone like you.
//Ban.
Old Feb 24, 2007 | 07:32 PM
Mil1ion's Avatar
Mil1ion
Well they're ignorant.... so what can they do ?
Change ?
