coolant whats going on
Old Feb 22, 2007 | 10:27 PM
hedhntr's Avatar
hedhntr
Drained my factory orange coolant 5 gallon bucket about overflowed filled it up with water and drained it again poured the exact same amount of green peak performance in everything good. Going through my chilton it says the coolant capacity is 33 qaurts so it sound like theres 3 gallons of the factory orange init if my math is correct. I havent started it yet should I or should I drain it again thanks
Old Feb 22, 2007 | 10:52 PM
monsterbaby's Avatar
monsterbaby
It's almost impossible to get ever single bit out, but you can get a lot closer by pulling the plugs out of the block, you leave almost all the antifreeze in the block when you just drain the radiator. And when you switch types of coolant like you did you need to not only drain it but flush it with distilled water at least once, run it and redrain it before putting in the new coolant. question is why are you going to green, you have to check teh SCA's with that and add the additives to keep them up. I switched from the green to the GO5 gold to get away from that.
Macs1964F100
19
Jan 27, 2024 07:19 AM
thinksnow
May 21, 2013 03:28 PM
greentree ford
Nov 15, 2012 04:24 PM
Phil Schroder
Dec 14, 2006 08:26 PM
