1978 - 1996 Big Bronco
NO OIL PREASURE AT SWITCH HELP!!!!!!!!!!
Old Oct 4, 2002 | 02:26 PM
JBronco's Avatar
JBronco
Old Oct 6, 2002 | 08:07 PM
Kaptain20's Avatar
Kaptain20
Freshly rebuilt 302. Pretty much new everything. Cant seem to get any oil preasure at the sender unit beside the oil filter. There is preasure however at the filter itself. Intermediet shaft is definetly hooked up. Any suggestions??????????????
Old Oct 6, 2002 | 08:32 PM
Hwy Apostle's Avatar
Hwy Apostle
have you tried a manuel gauge yet if so youve got a leak somewere probablyup top check for oil though. if not might just be a bad sending unit not uncomon.
http://www.drivingwithchrist.com/images/colt.gif
Please visit our Web Page for JESUS!!!
And we know that all things work together for
good to those who love God,
to those who are the called according to
His purpose.
(Romans 8:28)
GOD BLESS YOU ALWAYS
Agape: Jerry & Brooke Beasterfeld
Old Oct 7, 2002 | 02:22 AM
Kaptain20's Avatar
Kaptain20
I have tried a manual gauge. Still nothing. Its a clear tube for the manual gauge and there is no oil in it. I have even tried bumping the engine over with nothing in the block at all and no oil came out. We did have a leak at the back of the intake manifold but its fixed. Please correct me if im wrong, but shouldnt the preasure show before since the switch is right beside the filter. I have pulled the distributor and there is oil on it. As well if the valve covers are removed there is oil on the head. To me it looks as if its getting oil but the valve train is too noisey for this to be correct. Someone told me that the oil pump is very close ratio geared. It is a new oil pump, but if this is the problem then it is a major main to change. So I dont want to have to do it unless absolutly necasary. I would appreciate any more information that you might have. Thank you
Old Oct 7, 2002 | 06:03 AM
Pilotrick's Avatar
Pilotrick
[updated:LAST EDITED ON 07-Oct-02 AT 07:04 AM (EST)]Only way I know for sure to tell if it is the pump is to pull the dist. put a socket (the matches the pump shaft) on a long extension use a drill and turn the pump over you might leave the pressure switch out first to see if oil comes out there, if nothing at first give it a few minutes to prime the pump. BE SURE TO TAPE ALL PIECES OF SOCKETS TOGETHER SO NOTHING FALLS DOWN IN THE ENGINE. If you still have no oil pumping then I would probably say it was the pump or where the pick-up mounts to the pump might be lose and causing a leak there both are a major bummer to fix though. Only thing I can think of, Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old Oct 9, 2002 | 06:17 PM
cajunbronco's Avatar
cajunbronco
Are you sure the distributor is sitting all the way on the oil pump shaft?Is the shaft engaged in the pump?Did you replace the shaft,there are two different sizes.If you go to autozone you can rent a tool to hook up to a drill and prime the pump.Make sure you get the smaller of the two tools.You will need a good drill.Pull a valve cover and leave the sending unit off,check for oil at both places.It is remotely posssible that gasket sealer(If to much was used somewere)or something could have the oil screen plugged.If you run the drill to prime the pump it should really load up and almost bog down if the pump is working properly.
Billy
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
