Tractor work light...which wire is negative?
Old Feb 22, 2007 | 05:11 PM
ag-ford-4x4's Avatar
ag-ford-4x4
I need to install it, but there are no directions. Both wires are black. The only difference is that one wire has printing on it, like its size. How can i tell which is positive and which is negative?
Old Feb 22, 2007 | 05:20 PM
cdrmotorsports's Avatar
cdrmotorsports
Can you post what type of light it is? Is it the one in the rubber housing? I know that some of them are self grounding. If you can take it apart trace where both wires go.
Old Feb 22, 2007 | 05:22 PM
ag-ford-4x4
Its an Agribrite light, made by JW SPEAKER. its model 900. It has a ground wire and a positive wire, but i have no idea which is what. BOTH wires are black. I guess ill have to take it apart. I can't believe they arent labeled better than that. Maybe it doesnt matter which is what?
Old Feb 22, 2007 | 06:41 PM
76supercab2's Avatar
76supercab2
Incadescent bulbs are not polarized. Doesn't matter what direction they hook up.
The fact that these wires are not color coded indicates to me it doesn't matter which way they hook up.
If it's an led setup or some other type of light that must be polarized, then I don't know.
Old Feb 22, 2007 | 06:57 PM
79-400-POWER's Avatar
79-400-POWER
what he said
Old Feb 22, 2007 | 07:55 PM
thefarelaneman's Avatar
thefarelaneman
If the tractor is an old 9n it has a positive ground system. As far as which wire goes where, It makes no differance as long as the current is entering on one wire and grounded with the other wire to complete the circuit.
Old Feb 23, 2007 | 06:37 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Generally. . . it doesn't make any difference.
However. . . check the wiring, itself.
Look to see if there is a 'rib' on one of the wires (insulation). If so, this typically, is the ground wire.
Or. . . look at the wire. Is one copper (or brass) colored and the other silver (tinned)?
The silver or 'tinned' wire would usually be ground.
Old Feb 23, 2007 | 08:52 AM
ag-ford-4x4
This is a 2004 tractor, the light is brand new. There is no ribbing on it, but there IS printing, like gauge, etc. It has a push button switch, so i am thinking it is not polarized as you guys said. Its just a halogen light.
Thanks!
Old Feb 23, 2007 | 09:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
if you have a ohm meter, put one lead to a wire, and the other to the mount and check for continuity. then do the other side. this will tell you if one of the wires is grounded to the mount. if there is not a grounded wire, it can be hooked up either way.
Old Feb 23, 2007 | 09:34 AM
76supercab2
HOLD ON!! Any chance this bulb has two elements? (High beam, Low beam?) If it does then the two wires both go to +12 and the light grounds through the case. Best to get an ohm meter and check it out.
Measure between both wires and the case of the lamp assembly. If the circuit is open, then one wire to + and the other to -. If you get a resistance reading between the wires and the case, it might be a two filament bulb grounded to the case.
I still think it's probably a single filament and the wires don't matter. Connect one to the frame of the tractor and the other to + (or - if it's a + ground system)
Old Feb 23, 2007 | 12:33 PM
Mil1ion's Avatar
Mil1ion
IMO, The reason it has 2 wires is because of the possibility of water getting involved.
Like boat trailer lighting, it is considered a marine application and needs to be grounded directly. not through the case or mount.
Old Feb 23, 2007 | 02:02 PM
ag-ford-4x4
no, just a flood light, no hi/lo.
Thanks for the info. I think this will work!!
Old Feb 23, 2007 | 07:16 PM
SPL Tech's Avatar
SPL Tech
If the bulb is an incandescent bulb it does not matter which wire you hook up to ground. It’s not polarized.
Frapper
Aug 7, 2012 08:08 PM
*2fords*
Feb 25, 2010 09:25 PM
z 97ford1
Oct 20, 2008 06:42 PM
woogs
18
Jan 11, 2006 09:30 AM
Supercab
Feb 10, 2003 07:28 PM
