1978 - 1996 Big Bronco
no start
Old Oct 10, 2002 | 02:15 PM
aj5601's Avatar
aj5601
no start
[updated:LAST EDITED ON 10-Oct-02 AT 03:16 PM (EST)]ok, i drove to a friends house, everything went fine. we did some running around and went back to his house. no i went to start my 79 and all it does is crank. when i let go of the key it sounds like it is about to start but nothing happens. all my electrical is fine, i am getting fuel in my carb, but nothing is happening. any opinions out there? do you thing ignition module, coil, cap and rotor???? please help. i don't want to have to drive my wifes chevy around!!!!
i also have this posted in the engine forum also.
Old Oct 10, 2002 | 04:08 PM
Pioneer Ford's Avatar
Pioneer Ford
no start
You've got the right idea. I'd start at the coil and work my way to the plugs until I find the proble. Sounds like your not getting a soark. Could be anything betwen the coil and the plugs. Use the tried and true, "trial and error" methood. Good luck
Old Oct 10, 2002 | 07:43 PM
Scooby2's Avatar
Scooby2
no start
Don't forget to check your timing chian/gears. I had the same thing happen to a 79 LTDII with a 351.....it ran great until I went to start it the next day......:-X23 it would sound like it was starting to fire up but just died when the key was released.... Good Luck
Old Oct 10, 2002 | 09:18 PM
aj5601's Avatar
aj5601
no start
well, i just wanted to let you all know, i went back to my truck and i pulled mu coil wore off to see if i have spark and it fired right up....go figure. well i plan on getting all new ignition stuff for it, thx for the help
Old Oct 11, 2002 | 11:46 AM
tw's Avatar
tw
no start
WHITE_POWERSTROKE
40
May 21, 2021 11:47 AM
Bill Reich
Nov 10, 2015 10:20 PM
1Austin112
Aug 23, 2015 02:02 PM
sublime88
Bronco II
Apr 21, 2015 01:58 PM
whporwil
6.4L Power Stroke Diesel
Jan 26, 2009 06:35 AM
