1978 - 1996 Big Bronco
OK NOW IM LOST
Old Oct 11, 2002 | 06:37 PM
Kaptain20's Avatar
Kaptain20
OK NOW IM LOST
Thank you everyone who has helped me with all my little problems here. Thank you denis for informing me there is no frost plugs under the timing cover. You just saved me a lot of work. The problem that I am having is no oil presure at the switch. The oil is being pumped out into the filter. I have checked a manual gauge and there is definetly no oil at the problem point. When i went to the machine shop to find out why I might be having this problem I was asked if I installed the frost plug under the intake manifold.....which i had not. I know that all the plugs on the back of the block are in. Now, i still have the no presure problem even after correcting my mistake. I am really out of ideas and need some help badly. I assumed that since there are frost plugs on the side top and back that there must be at least one on the front but apparently not. This is really turning into a huge headache and I would really appreciate it if someone could point me in the right direction.
Thanks so much
Geordie Ballantyne
91 Ford Bronco
302
Old Oct 11, 2002 | 07:17 PM
JBronco's Avatar
JBronco
OK NOW IM LOST
