Window track
Old Feb 22, 2007 | 08:05 AM
illinois4by's Avatar
illinois4by
Window track
My stupid window track fell off the bottom of my drivers window. You guys know of anything i can use to put that back on, looks like it just used adhesive. Maybe i can use construction adhesive? Oh where on earth do i find performance parts for a 300-6
Old Feb 22, 2007 | 12:36 PM
lostin90s's Avatar
lostin90s
I used cleaned real well and used silicon adhesive. It worked 3 yrs till I parked it.
Old Feb 22, 2007 | 12:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Common problem. Frame is held to window glass with glass tape. It may, however be broken, another common problem. What happened is one of the window rollers, which are in two pieces broke, another common problem. Since there are two per glass, one held the window up till it finally gave up.
If yours is the plastic crappola type, the Ford replacement part is usually steel.
Old Feb 23, 2007 | 07:57 AM
d79f150's Avatar
d79f150
Try www.fordsix.com
www.cliffordperformance.net
SJMaye
1997 - 2003 F150
Oct 21, 2014 04:59 PM
petercrabbe
Jan 11, 2014 08:14 PM
BigBlueCat
Jun 30, 2012 01:06 AM
wertz49
May 10, 2009 12:23 AM
pashtrd
General Automotive Discussion
Oct 11, 2006 07:44 PM
