Help please
Old Feb 21, 2007 | 07:02 PM
pnut's Avatar
pnut
Help please
I need to know which relay is my fuel pump relay in my under hood fuse block i need to do a compression test and need to shut off fuel
Old Feb 21, 2007 | 07:16 PM
RangerPilot's Avatar
RangerPilot
There should be a diagram stuck to the roof of the box.
And you didn't say what year, so we dunno...
....BUT....the MUCH easier way would be to just disconnect the intertia switch located at the very front of the passenger footwell...by doing so it will cut all power to the fuel pump.
Lay in your passenger footwell, pull the front carpet back justa little bit, and you can see it. It's a grey or black box with a big red button at the top and two wires coming out the bottom, screwed into the firewall. Take a screwdriver and unplug it. Voila, fuel pump disconnected.
cuttr28
31
Nov 1, 2014 07:37 AM
jc43white
Aug 21, 2013 03:21 PM
jcichino
Jan 10, 2013 04:44 AM
WildlandFirefighter
Aug 20, 2011 03:55 PM
northwoods1990
Jan 1, 2011 03:43 PM
