Thanks to several folk here, I'm getting closer to the final design on the stakebed I'll build for my 48 F1. I like the idea of having a lift capable bed too, and have been eyeballing the air actuated hydraulic cylinders that are around for use on cherry pickers. The thought struck me that if a reasonable sized on board compressor could be added, then this type of cylinder would work nicely as a way to tilt the bed. So...... are there among this group some that have used such compressors for air suspension, air shocks, etc?
I've seen the ads in the trucking magazines and the prices seem pretty scary. Are there industrial versions around that aren't priced like they are made of gold?? Also .... what about small air tanks to store the air? Thanks in advance for thoughts on this idea.
Hi
I purchased my compressor and air tank from a company called Suicide doors. Here is the link. http://www.suicidedoors.com/AirManagement.php
They have a real nice stainless steel 5 gal. tank for only 79.99 and they also have a wide selection of 12 volt compressors. I selected the Viar 380 which can compress to 200 psi for $184.95 but they have others which are lower priced.
Rick
(Big) truck parts dealers can sell you a sausage tank like the Euclid E-10732, 8" diameter, 32" long, 1425 cubic inches, rated 150 psi.
The A/C compressors need to be belted up to the engine, but if you have an engine where stock A/C brackets are available, that's an easy install. Do a search for "on-board air" and "york compressor" and you'll find plenty of info.
Worn-out mini home compressors are a useful source of parts, like the safety valve, pressure switch, regulator, check valve, if you can score one from a yard sale or trash day. It could be worth buying one new just for those parts.
The information I found following your lead on this was perfect. I found 4 excellent articles on how to do the whole thing, and for very reasonable costs. The ironic deal on this is that I already have most of the pieces. Just need to get a tank, and a few fittings. Great advice you provided, and right on the money for usefulness.
