1978 - 1996 Big Bronco
Check Engine Light on My Bronco
Old Oct 9, 2002 | 04:00 PM
DeGideo's Avatar
DeGideo
I guess I'm going to have to see what codes come up.It's weird,because the check engine light comes on only sometimes,and usually after driving 5-10 miles.It stays on for a few minutes,then goes off.It's been happening for a few weeks.Haven't had a chance to check the codes.Figure it's the TPS,or maybe an oxygen sensor.Drove it out to Carlisle last week-no problem-the check engine light never came on.Even 2-3 days later,in around town driving(stop&go),the light never came on again.As of yesterday,it started up again.It's running good,but I want to find little problems,and fix them,before they have a chance to become big ones.It ran WONDERFULLY on the PA. Turnpike,driving out to Carlisle.
Old Oct 9, 2002 | 06:16 PM
AlM's Avatar
AlM
yo D!
I forget what year you have so for a simple one which i try first, check the gas cap. After running the Bronco for a bit, shut the engine off and unscrew the cap and listen (or feel) for the slight negative pressure in the tank. Could be a loose cap or a bad cap gasket.
then, the rest of the usual CEL faults that you mentioned + all the others that the codes will help you with.
Old Oct 16, 2002 | 05:57 PM
edenroadmaster's Avatar
edenroadmaster
AIMs right about the gas cap. my buddy has a garage and makes a killing on hooking up the code reader just to find its a gas cap.
where are u at in pa? I live south of lancaster.
edenroadmaster
Old Oct 16, 2002 | 08:42 PM
heybrent's Avatar
heybrent
