brakes
Old Feb 21, 2007 | 12:56 AM
warlock-jim's Avatar
warlock-jim
Cool brakes
I Have Read All Previous Threads On Bleadiing Brakes, 1993 F-350 Dually,this Makes #6 Mastercylender Which Is A F-450 Napa New. Bypassed Rabs Valve. Bled Everything ,including Gravity.stiff Peddle Except When You Start The 7.3 Litre. 22 On Vacume Gauge, Then It Is Spounge And At The Floor. What Is It With These Trucks? Even The Power Booster Is New. Every One I Talk To Say Good Luck Trying To Get Them To Work There A Nitemare ............i Got My Trans Working Now I Cant Race Because I Cant Get Brakes To Savve My Butt......please Someone Help Before I Loose All My Hair....
Old Feb 21, 2007 | 01:37 AM
mobilemvr's Avatar
mobilemvr
maybe an expanding rubber section of a brake line. have you tryed braded lines? this was the issue with my 93 f250, and i replaced the front calipers and powerbooster, the pedal would still drop to the floor, it was the driver side fron brakeline that crapped out and was expanding like a ballon in one spot when i pressed the brakes, i upgraded both fron lines to braded hoses that i got from a machine shop for 80 bucks for the pair.
Old Feb 21, 2007 | 08:45 AM
warlock-jim
front lines are new, i just put gauge back on and pushed pedal down and gauge went from 22 slowly went to zero . if you pump pedal it rapidly goes to zero,if you hold pedal to floor gauge slowly moves back up to22. thanks jim
Old Feb 21, 2007 | 09:11 AM
Ben-jamin's Avatar
Ben-jamin
have you checked the rear rubber line? how's the adjustment on the rears?
if you pump them enough you will show low vacuum also.
Old Feb 21, 2007 | 01:20 PM
PLC7.3's Avatar
PLC7.3
Have you done a vacuum test on the vacuum pump.......
Old Feb 21, 2007 | 02:04 PM
warlock-jim
no, i put gauge on vacume port and show 22 on port. do you get adifferent reading on pump ?
Old Feb 21, 2007 | 02:39 PM
86fu50's Avatar
86fu50
No vacuum will make a hard unresponsive pedal.
How new is the booster? If you installed it did you adjust the pushrod on the new one? Have you looked at your calipers? Or wheel cylinders? any leaks or weeps?
Old Feb 21, 2007 | 02:58 PM
j tate's Avatar
j tate
i would allmost bet the rear brakes are out of adjustment, mine did the same thing and did all the same things you did (change everything) did new brakes on back, just like new.
Old Feb 21, 2007 | 03:02 PM
j tate's Avatar
j tate
with the way you described that it sounds like you have a bad booster.
Old Feb 22, 2007 | 01:47 PM
warlock-jim
just replaced power booster that was a tear old and now i have brakes,all that and it was seeping at the output shaft thanks for all the help............JIM
DansBBF250
20
Jun 30, 2010 08:45 PM
74scamp
Aug 3, 2009 10:28 AM
csangster
Sep 1, 2008 10:27 AM
lambert
Mar 3, 2005 06:04 AM
qsteeler
Jul 17, 2003 03:28 PM
