Another Turbo Question
Old Feb 21, 2007 | 12:10 AM
cdiddy's Avatar
cdiddy
Question Another Turbo Question
Trying to understand this turbo stuff. My question is what would this do for my stock trubo? Will this make my turbo more loud? Also would I want the wastgated or non wastgated? Im talking about the first one here. The 1.0 turbo housing kit.
http://www.beansdieselperformance.com/99-03turbo.htm
Old Feb 21, 2007 | 07:40 AM
mech2161's Avatar
mech2161
Need to fill in your signature at the bottom to make it easier to help you.
Will it make it louder - yes.
Wastegated or not - depends on your mods. I would think non.
Old Feb 21, 2007 | 07:46 AM
Pocket's Avatar
Pocket
With average mods (ie chip, intake, exhaust), you can get away with the non-wastegated housing. If you plan on some mild injectors or other go fast goodies, then you'll need a wastegate.
The purpose of the wastegate is to bleed off excess exhaust gasses. This helps to reduce drive pressures before they get too high and destroy your turbo. A larger turbine housing already reduces drive pressures as it is able to move more exhaust, but if you are adding a ton of fuel, then you are right back where you started.
cdiddy's Avatar
cdiddy
Really no mods, just a hypertech III programer for now. I have the WW and the 6637 ready to put on as soon as I get the rebuild kit in for the turbo.
Old Feb 21, 2007 | 10:17 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
If your looking to make for more turbo sound, ****** the foil off the intercooler tube and remove the hood insulation. Then use the money you would spend on the housing and get a DP-Tuner and gauges.
