Heater problems
Old Feb 20, 2007 | 10:56 PM
Stoogefan's Avatar
Stoogefan
Heater problems
Hey folks ... I've got a good one, hope maybe I can find a little help.
I've got an `85 F150 with a 351W ... easy enough. Now, here's my dilema ....
when I go out in the morning to warm the ol' girl up, the heat/defrost won't fire up until I put the truck into gear, then back in park. On top of that, the signal lights won't work either ... until I put it into gear. No biggy since I don't need the signal lights when the truck is in park in my driveway, but I thought I'd throw it in... hehe Sad thing is ... it doesn't ALWAYS do this.
Any ideas what the problem might be ??
Thanks .... Jeff
Old Feb 21, 2007 | 04:33 AM
ccecilm2's Avatar
ccecilm2
Could be a gumed up ignition switch. Mine needs cleaning up at the least because when I start it I have to make a conscious effort to turn the key back to the "run" position or none of my accessories will work.
Old Feb 21, 2007 | 09:07 AM
Stoogefan's Avatar
Stoogefan
Thanks for the info. Now that you mention the "gummed up" ignition, I do in fact from time to time have to turn the key back a little after I start the engine, otherwise I'll be looking at a starter replacement as well. I'll give it a good cleaning once the weather turns a bit nicer.
Thanks again ...
Jeff
thatsrealnice
16
Jul 31, 2020 06:00 PM
lunatech
Apr 18, 2014 11:50 PM
micklskot
16
Apr 4, 2009 01:10 PM
0rion
Electrical Systems/Wiring
Nov 8, 2007 06:47 PM
