1978 - 1996 Big Bronco
replace Manual Lever Position Sensor (MLPS)
Old Oct 3, 2002 | 08:30 PM
HIGH_N_DRY's Avatar
HIGH_N_DRY
[updated:LAST EDITED ON 03-Oct-02 AT 09:47 PM (EST)]Does any know the replacment procedure, special tools, etc.......?
Much obliged.
I see the post by Dan, but thats late 80s is it same for 95?
Old Oct 14, 2002 | 07:33 PM
86scoot's Avatar
86scoot
No special tools or equipment needed. It has an N on the side of it for neutral. Make sure your tranny is in neutral, line up the mark and tighten the bolts.
Leroy
Old Oct 15, 2002 | 03:24 PM
AlM's Avatar
AlM
yo,
In case you haven't verified that the mlps is bad, here is quick check for a connector problem:
http://autorepair.about.com/library/faqs/bl417c.htm
and a test site that may help you:
http://www.transonline.com/transdigest/magazines/1998-10/Shift%20Pointers/index.html
Old Oct 16, 2002 | 08:27 AM
AlM's Avatar
AlM
[updated:LAST EDITED ON 16-Oct-02 AT 09:51 AM (EST)]more, from AutoZone.
http://www.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d/80/0a/3c/ce/0900823d800a3cce.jsp
and the TSB:
http://www.4door.com/tsb.htm
Old Oct 20, 2002 | 06:16 AM
HIGH_N_DRY's Avatar
HIGH_N_DRY
Thank you for the information all
Much Obliged, Paul
Old Oct 20, 2002 | 01:56 PM
tothfngclw's Avatar
tothfngclw
davids38
2004 - 2008 F150
Apr 7, 2018 12:54 PM
frank01
Modular V8 (4.6L, 5.4L)
Apr 4, 2017 10:55 AM
Whitey Ford
Mar 9, 2017 05:24 AM
davids38
Oct 15, 2016 02:39 PM
peka
Jun 2, 2016 05:17 PM
