1978 - 1996 Big Bronco
little overheating
Old Oct 13, 2002 | 11:52 AM
YOURPAL68's Avatar
YOURPAL68
little overheating
Old Oct 20, 2002 | 01:45 AM
frankseahawk's Avatar
frankseahawk
little overheating
Hi I have a 95 Ford Bronco eddie Bawer 5.8 engine ( I just Bouth it) and im very Happy with it but there is something that bothers me the temperature gauge goes from normal to almost 3/4 in 5 minutes when driving on street just gets to 1/2 but on the highway goes a little bit more why ? I replace the thermostat the ratiator cap the engine seems to be working great but I just don like to see that needle going Higher any suggestios will be appreciated
Old Oct 20, 2002 | 10:57 AM
CityBronco's Avatar
CityBronco
little overheating
Sounds like the Water Pump might be going out or your radiator could be clogged. Then there is also the possibility that you are low on oil. Hope this helps, good luck!
Old Oct 20, 2002 | 11:07 AM
bronco cam's Avatar
bronco cam
little overheating
Take a look at your fan clutch also. It may not be locking up to allow your fan to spin fast enough to suck in the proper amount of air.
Old Oct 20, 2002 | 11:33 AM
georgedavila's Avatar
georgedavila
little overheating
Before replacing anything, check or have your 'gauge' checked.
Old Oct 21, 2002 | 11:18 AM
Redbob's Avatar
Redbob
little overheating
Like the man said, first check your gauge for accuracy; pull the sender, put an extension wire to the positive connector, put a ground wire to it, and put it in some boiling water - got a portable hotplate or a camp stove?
When you find out it's OK, then order up a new radiator...
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
