Sponsored by: Real Truck
bad vibration
Old Feb 20, 2007 | 06:42 PM
jmolin's Avatar
jmolin
bad vibration
i know there have been a bunch of posts about vibration, i was just wondering if anyone found a solution for this yet. i have a 2006 f250 fx4 supercab psd. i have the bad vibration when accelerating from a stop. Been to the dealer 4 times, they shimmed the carrier and replaced the driveshaft, and still have the vibration. The more weight i put the worse it gets. don't know what else to do, dealer giving me the run around saying that, that's as good as it gets. any help would be great.
Old Feb 21, 2007 | 03:43 PM
jmolin's Avatar
jmolin
pretty please with a cherry on top all you guys cant still be driving with that vibration
Old Feb 21, 2007 | 04:10 PM
kw5413's Avatar
kw5413
Looks like they have done what they know do to.. according to previous Tech bulletins that I have read.
I know this sounds simplistic but, how 'bout the tires?
Old Feb 21, 2007 | 04:28 PM
jmolin's Avatar
jmolin
never realy gave it much thougt, it only does it for a couple of seconds when i pull out and the heavyer the load or the steeper the hill the worse it is. i'll get the tires rebalanced though just to rule it out thanks
Old Feb 22, 2007 | 03:49 PM
Skoiv's Avatar
Skoiv
My 05 does the same thing from a stop. I just had the alignment done as well and it still vibrates.
Old Feb 22, 2007 | 04:14 PM
Onebadpolaris's Avatar
Onebadpolaris
I have a 2000 f250 and it does the same thing i had 33" tires on it and it vibrated like crazy off the line and went away and now im at 37" tires and it still does and the alignment and balance is perfect im guessing something to do with the rear end or driveshaft or something I dont know.
Old Feb 22, 2007 | 04:46 PM
hardint's Avatar
hardint
Jmolin, how many shims did they add to the carrier bearing ?I know up to three or 3/4" are allowed.IS the truck chipped or stock?My 05 crew cab 350 only does it on a steep incline with a loades trailer,I added two shims but have not had the trailer/load the same to make it show up.I also get the basketball dribble "bounce" on concrete freeways which is annoying as hell also,this is my first Ford and an employee for what thats worth.If you find the cure please post it for us "SHAKEN ONES".
Old Feb 22, 2007 | 07:56 PM
jmolin's Avatar
jmolin
my truck is stock for now but i want 8 inch and 38s im just afraid the vib will get unbearable. ive had 1 then 2 then 3 shims and i think its best loaded with 0 shims and empty with 3 shims its driving me nuts and i will find a fix i'll let you all know when i do theres got to be something. i noticed that (i hate to even say it but)a chevy has a one peice alum. drive shaft, maybe something along these lines could help us
Old Feb 22, 2007 | 09:37 PM
redford's Avatar
redford
FTE Leadership Emeritus
After 4 visits you probably had better make a choice; live with it or take it back again and start the lemon law process for your state.
Old Feb 22, 2007 | 09:46 PM
jmolin's Avatar
jmolin
has anyone had the vib and put a 6 or 8 inch lift? did it get worse better same? i could probably live with it as long as it dont get worse
Old Feb 22, 2007 | 09:47 PM
swanee's Avatar
swanee
If it gets worse with more weight I do not think shims are the answer. Weight would straighten the driveline angle and reduce the vibration. I seem to remember another TSB about the turbo pedestal or something causing similiar symptoms.
Old Feb 22, 2007 | 09:51 PM
jmolin's Avatar
jmolin
I did see that on here and mentioned it to the tech and he said that 06 model should already have the pedistal. is this not right?
Old Feb 22, 2007 | 10:13 PM
cc322's Avatar
cc322
You guys with the vibration running the stock Ford wheels? If not then you probably have lugcentric oposed to the factory hubcentric wheels. Heres the best way to get the hubcentric wheels centered to avoid all vibrations. You also may try a shop that does Road force balancing it works.
What is a Center Bore? Hub Centric vs. Lug Centric
The centerbore of a wheel is the size of the machined hole on the back of the wheel that centers the wheel properly on the hub of the car. Centerbores on wheels are typically a standard size by brand or size (measured in inches or mm). Hub sizes vary by vehicle brand and style.
When this hole is machined to exactly match the hub so the wheels are precisely positioned, minimizing the chance of a vibration, it is said that the wheel is “hub centric”.
Some wheels require centering rings that lock into place in the back of the wheel in order to become hub centric and reduce the risk of vibration while driving. This is an acceptable alternative.
If you don’t not have hub centric wheels (lug centric), they should be torqued correctly while the vehicle is still off of the ground so they center properly. The weight of the vehicle can push the wheel off-center slightly while you're tightening them down if left on the ground.
This is the road force balance I only use this method and it works great on my 35's
http://www.craigautometrics.com/huntergsp9700.htm
Old Feb 22, 2007 | 10:52 PM
993/4ton's Avatar
993/4ton
I had the vibration when it was stock height with 33's. I have since put on a 6.5 inch lift and 37's. I also put ladder bars on the rear axle. The vibration is gone. I would venture to say it might be an axle wrap issue. These are pretty heavy trucks, with lift blocks on the rear axle...
Old Feb 23, 2007 | 03:14 PM
jmolin's Avatar
jmolin
sounds good to me. i'll just put on my lift and tires, order up some traction bars, and road force balance the tires. thanks alot guys.this is by far the most informative site out there thanks again.
den21011
Feb 16, 2007 07:52 PM
brd1putt
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 20, 2007 05:27 AM
72 high boy
Jan 4, 2007 11:13 PM
BroncoBoss351
1978 - 1996 Big Bronco
Nov 28, 2005 01:32 AM
mjs
Jun 21, 2005 09:46 AM
