1978 - 1996 Big Bronco
Killing new battery !!
Old Oct 16, 2002 | 08:39 PM
luxury 4x4's Avatar
luxury 4x4
Out of noware the truck battery is completely dead... So I replace
it because the old one was due. I clean up the connectors and (Ect.)
two days later the new battery is COMPLETELY dead.
So I recharge it and I go through the truck completely checking
all lights stereo amp. glove box Ect. And nothing is on or drawing
power but it still dies in two days what would be the next suggestion
I also took a volt meter to the battery and removed fuses one by one
and no voltage drop.. so I dont know what's next
Any help would be great.........Thanx
Old Oct 16, 2002 | 09:14 PM
Pilotrick's Avatar
Pilotrick
First have you used a hydrometer on the new batt? Second have you tried removing the neg batt cable and put a test lamp between the cable and batt post to see if it lights up and if it does try your pulling fuses routine to see what is drawing the power. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old Oct 16, 2002 | 10:50 PM
mrwizard's Avatar
mrwizard
Have you checked to make sure the alternator is working? Normal volt-meter readings should be around 12V or so across the battery when it's not running, and 13V - 14V across the battery when it is running. i.e. you should be able to see that the alternator is increasing the voltage when the engine is running.
Not sure about yours, but my '85 had a seperate voltage regulator that I had to replace twice because my battery wasn't getting charged.
Old Oct 16, 2002 | 11:28 PM
Flash's Avatar
Flash
With the motor off and key off. Take the battery lead terminal off of the alternator and check for a small amount of arching. If none, leave it off unless you are driving it. If the lead archs the alternator has suffered a spike and needs replacement. If the problem goes away with the terminal off, the alternator has a fried diode. DO NOT replace with a discount alterntor. Use new Ford replacement only.
Old Oct 19, 2002 | 09:19 PM
luxury 4x4's Avatar
luxury 4x4
Thanks dudes. I will definatly try your suggestions Jeff.
Old Oct 21, 2002 | 08:35 PM
luxury 4x4's Avatar
luxury 4x4
Thanks fellow fordsters after 4 hours and no schmatic I narrowed
it down to the EEC relay sticking closed...
Best part was it's only a 15.00 relay from the parts house
Sweet deal thanks again for the pointers Jeff
Old Oct 21, 2002 | 08:36 PM
bronco351's Avatar
bronco351
Billncsu
1997 - 2003 F150
Nov 29, 2010 02:56 PM
a ayala
May 6, 2010 09:29 PM
willbill28
May 5, 2004 02:07 PM
bfuller
Apr 24, 2004 03:27 PM
RonDogg
Oct 29, 2001 07:00 PM
