Modular V10 (6.8l)
Steering Column Whistle?
Old Feb 20, 2007 | 02:43 PM
wfof250v10's Avatar
wfof250v10
Question Steering Column Whistle?
Hey guys I've never posted anything before, but love the info that comes from the site. I've got an issue with my steering column whistling, usually when I'm towing and the brake control is on. Have any of you had this problem, I'm not sure its a problem YET?
Old Feb 20, 2007 | 05:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
Should we all assume that it won't do it if the brake controller isn't hooked up?
When does it whistle? When turning the wheel or ?
Old Feb 20, 2007 | 05:38 PM
Fredvon4's Avatar
Fredvon4
Sparks Nevada (easier to type then your screen name)
Tell us a lot more about the vehicle
05 ford trucks with some front end issues have a TSB that recommends replacing the steering wheel itself...I had this done and still have no earthly idea what it was supposed to do to fix a front end oscillation
You might have steering pump whine resonating up the column but it would be the first I heard of this... you night have too much or too little tongue weight and when towing the front end is too light or too heavy and causing tire noises resonating up the shaft
This is a new one...whisteling steering column...is it a tune we could hum along with?
Old Feb 21, 2007 | 11:44 AM
wfof250v10's Avatar
wfof250v10
It's not a whistling tune to sing along with....it only has done it right after starting the the truck both with the 9,200 lb 5th hooked up and not hooked up. the streering pump resonating might be something to check out. I hope the 5th isn't to heavy. I am upgrading from the 3.73's to 4.30's this month to increase the towing capacity.
Old Feb 21, 2007 | 12:05 PM
wfof250v10's Avatar
wfof250v10
I noticed the truck info isn't showing. I have a 04 F250 SD V10 4X4 with 3.73 rear, 12.5K hitch, off road package, superchips tuner for towing and no other mods yet.
Old Feb 21, 2007 | 12:11 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The weight of the steering wheel was just enough (or not enough) to set up a harmonic with the spool valve in the steering box. Hit a bump just right, the steering box moves slightly to one side. The spool valve opens up, putting pressure to push the wheels back the other way. Somehow, the weight of the steering wheel pushing back on the spool valve was enough to cause the spool valve to rapidly cycle back and forth causing that "death wobble" - or at least, that was the working theory
Don't know if it really did anything though...
Anyway...
This is an interesting topic...
Go over how it happens again. Just after starting? Doesn't matter if the trailer is hooked up (electrically!) ??
Old Feb 21, 2007 | 03:20 PM
wfof250v10's Avatar
wfof250v10
Just after starting the truck, the whistling sound starts and lasts for maybe 30 seconds. It's done it the most with the 5th attached and electrical hooked up, but it has made the sound after unhooking the 5th. Again it only lasts for about 30 seconds. It hasn't made the sound in a couple of months since its winter here in the Sierras and we've not gone camping lately. The last time it made the sound I took a cardboard tube and listened to see where the sound was coming from. It appeared to be on the cab side of the firewall and definitely from the column, but it's hard to pin point exactly where since its an intermitent whistle. I just realized the location of the Tekonsha brake control is near the steering column, maybe the sound is coming from that.??? Weird, I may have to hook up again just to check with the cardboard tube again.
PS: the info from everyone and this site is so valuable!!!...how do you become a supporter?
Old Feb 21, 2007 | 04:23 PM
krewat's Avatar
krewat
Go here:
http://www.clubfte.com/
It very well could be the controller going through it's startup diagnostics, if it's that smart.
Does it apply the trailer brakes for that first 30 seconds? Could be the electronics for the brake pulse-width modulation making some noise ...
Old Feb 21, 2007 | 05:13 PM
wfof250v10's Avatar
wfof250v10
we'll see if its coming from the brake control when I hook up later...thanks!
I just became a supporter so I'll be picking everyones brains for info..greg
Old Feb 21, 2007 | 05:33 PM
Fredvon4's Avatar
Fredvon4
Ask away we love a mystery
I bet it is steering pump noise, or brake booster vacuum, or brake controller filling a capacitor like a flash charge tube on a camera.... in that order is how I would eliminate things
Both the steering pump and brake booster could be checked with a longer gift wrap tube with hood up and some one else do the cold start so you can quickly see if pump or vacuum.....
I bet it is a whiner steering pump, and if so, the fact that it quits in 30 seconds probably means it is not going out but just a cold noisy one
Old Feb 21, 2007 | 05:36 PM
Monsta's Avatar
Monsta
Sit. Stay.
Greg, what kind (brand) of brake controller do you use?
Old Feb 21, 2007 | 05:40 PM
wfof250v10's Avatar
wfof250v10
Its a Tekonsha
Nick9219
17
Sep 12, 2021 11:40 PM
Kittycat1979
Aug 28, 2016 07:50 PM
BogginDave
Dec 30, 2015 08:21 AM
Willk98k
Dec 18, 2015 08:14 PM
bunky383
Jul 25, 2015 10:38 AM
