EGT Probe location?
Old Feb 20, 2007 | 09:26 AM
ECA's Avatar
ECA
EGT Probe location?
Was trying to locate the EGT probe for my Edge, could not find it so far.
Where should it be? I thought it would be at the top of the exhaust downpipe somewhere. I do see a probe connected to the manifold, could this be it?
Thanks,
Old Feb 20, 2007 | 09:30 AM
EARLYTIMES's Avatar
EARLYTIMES
Yep, that's probably it
Old Feb 20, 2007 | 10:25 AM
Lonewolftx's Avatar
Lonewolftx
Talking
Sounds, or looks, like a wiener . . .
Old Feb 20, 2007 | 10:35 AM
ballbandit's Avatar
ballbandit
Thumbs up
If it was installed right the probe is in the drivers side exhaust manifold. can be seen by crawling under the truck.
Old Feb 20, 2007 | 11:26 AM
Lonewolftx's Avatar
Lonewolftx
Red face
You should send him a pic. Everyone has talked about mounting on the drivers side exhaust but no has posted a ic of where they mount it.
Old Feb 20, 2007 | 11:29 AM
ECA's Avatar
ECA
Thank you. That is right, I can clearly see the probe at the bottom of the drivers side manifold.
In the past someone commented that it must be installed wrong after I said what EGT I was seeing.
Old Feb 21, 2007 | 12:07 AM
ballbandit's Avatar
ballbandit
What egt was you seeing? I have seen them get pretty high before, like 1300.
Old Feb 21, 2007 | 02:26 PM
ECA's Avatar
ECA
BBandit, Have not seen anything close to that. 875f is the max I have seen going up a small hill. I do not have a heavy trailer, only a bass boat.
